    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • OscarLokO
      OscarLok
      OSCAR
      In your Oct release, only three icons are displayed. And the last two, cut and intersect perform the same function.
      Thanks for your work with this plugin.
      Ken
      Hello Ken,
      I am sorry for that! I have changed it to the New OCT version. The previous one is still Sept version.
      Thanks Ken 😄
      Oscar
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • shuraS
        shura
        Does it work in SU 7.1 as well?
        • OscarLokO
          OscarLok
          This is a SU 8 only。Maybe in the next next version。。。。 😉
          • shuraS
            shura
            thanks oscarlok, just collecting reasons to upgrade, you know 😉
            • mitcorbM
              mitcorb
              I never could get the version for Sketchup7 to work??
              • mitcorbM
                mitcorb
                Bumping this just in case someone knows a solution to making the older version work in SU7?
                  Someone said that disable SketchyPhysics permits to use OSCoolean in V7 (?)
                  • mitcorbM
                    mitcorb
                    I do not have Sketchyphysics. Must be some other tool. I will try to run it with the console on, capture and post back.
                    • mitcorbM
                      mitcorb
                      Here's what I get trying to Intersect a simple cylinder group and a cube group which I set overlapping or coincident in the same location :
                      Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0x6775c40>> (eval):573:in get_grocom'
                      (eval):570:in each' (eval):570:in get_grocom'
                      (eval):588:in Preset' (eval):713:in Intersect'
                      (eval):823
                      (eval):823:in `call'
                        (eval):823
                        ComponentInstance doesn't have an entities method - you need to access the definition.
                        There are some plugins that adds .entities to ComponentInstance and I've seen some other plugins that also made the assuption taht this method existed.
                        • mitcorbM
                          mitcorb
                          Hi, ThomThom:
                          Thanks for your quick response.
                          Unfortunately, you're talking way over my head 😳
                          I mean, I see what you're writing but I don't know what I'm reading 😆
                          What means 'grocom' ??
                            @mitcorb said:
                            Hi, ThomThom:
                            Sorry - it was intended for Oscar.
                            Just method name.
                            • mitcorbM
                              mitcorb
                              You did note that this is for V7? I am not ready for V8 just yet.
                                Works fine for me for SU 8 free 😄
                                I click first on the icone then objects ! 😎
                                • HumpmetwiceH
                                  Humpmetwice
                                  I love this plugin but wasn't able to get it to work with SU 7.1, I know its for v-8 but was hoping someone had a fix!
                                    and what is the problem to not load the V8 in another folder and save as V7.skp ?
                                    • HumpmetwiceH
                                      Humpmetwice
                                      Nothing I was just wondering if it was a fix for v7.1 is all.
                                      • OscarLokO
                                        OscarLok
                                        @doodledown said:
                                        Thanks for this, very excited. I just upgraded to 8 for this, but the plugin isn't showing up. Are there any dependencies or known conflicts that could be at fault?
                                        My plugins folder only has the folders Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. (Obv there's also OSCoolean.) I'm on 7 Pro.
                                        Thank you very much, whether or not you can point out what's wrong!
                                        Do you have the Oscar folder inside your plugins folder in 8?
                                        or try to unzip the OSCoolean again into your plugins folder in 8, please.
                                        Oscar 😄
                                          DoodleDown
                                          Yeah, I downloaded and unzipped the folder and the file into Plugins several times. Mucho wierd.
                                            DoodleDown
                                            My Sketchup 8 plugins folder only has the folders Oscar, Cadspan, JPP_Dir_15, LIBFREDO6_Dir_34, Ocean, TIGtools, TOS_Dir_16 plus Utilities, plus the rb files OSCoolean, deBabelizer, extrubeEdgesby(various things), jointpushpull, LibFredo6, LibTraductor, loop_subdiv, ocean_extension, su2stl, ZLoader_OnSurface and utilities, if that for some reason makes it obvious to anyone. I'm on 7 Pro.
                                            • 15
                                            • 16
                                            • 4 / 16
