    Prince IO Sketchup Game Demo
    42 Posts 26 Posters 32.3k Views 26 Watching
      chief1234
      Right, changing the code to run on top of the current model would be ideal.
      Unfortunately, I'm a novice at Ruby so I'm not quite sure how to do this...
      I tried removing any direct references to maps in the file_loaded? method at the bottom. This way the engine will run, but only on maps AFTER they have been hardcoded, run, then the code removed again...
      Obviously I'm missing a vital part of the puzzle...
      Any help out of your busy schedule would be greatly appreciated!
      Thanks,
      Luke J.
        toxic
        Thats fantastic
        So when do we get worms
          trickout
          when i try to go to the linked site for the .zip, it says sight unavailable
          can someone post it somewhere else?
          • scottliningerS Offline
            scottlininger
            Hello trickout. Terribly sorry for the broken link. Please try again.
            Cheers,
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              trickout
              Thank you for fixing the link. How can I edit the code, for instance make it move in 3 dimensions instead of just on a plane? I've tried to find a .rb editor but no success. 😞
                todd burch
                .rb files are merely text files. Notepad, Textedit, lots of editors will work. Always save as plain text.
                  August
                  ... You can hear more details from the original preso: http://www.youtube.com/watch?v=FALvwBN5-hc
                  YouTube says: "We're sorry, this video is no longer available."
                  Any alternate sources?
                  Thanks,
                  August
                  β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                  [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                    scottlininger
                    Hey August,
                    I've sent a query to the code site folks asking what happened to the video.
                    Thanks!
                    • Scott Lininger
                      Trimmer
                      Hi Scott,
                      I'm Having the same problem BTM did back in Nov:
                      I have a mac running OSX 10.5.6, and for every frame, I encounter the error
                      %(#808080)["newGroundz:
                      value=>-5000<
                      TypeError: Value undefined (result of expression value.split) is not object."].
                      the error pops up first, i have to click enter, then next frame, same error, this repeat over and over, then the knight falls through the floor, screams, and SU messes up. Any idea why?
                      I'll need to test on my Mac with SU7 and post a fixed version.
                      Have you found a way to correct this?
                        driven
                        Hi All,
                        did anyone ever get this running on a Mac? can something be changed to make it run?
                        john
                          todd burch
                          This was working on a Mac back when Scott posted this thread. Did someone or SU break it since then?
                            driven
                            hi Todd,
                            I only downloaded it recently and it appears to have the same symptoms as BTM's early post described, so I thought it had not been fixed....
                            or the solution had moved on to a different thread, as sometimes happens...
                            so, it's not currently working on 7.1 on a Mac and although I'm happy to modify the code, I'd need some instructions.
                            cheers
                            john
                              scottlininger
                              Hmm. Todd's cleaned up version was working on mac. I'll take a look...
                              • Scott Lininger
                                driven
                                Thanks for that...
                                john
                                  MartinRinehart
                                  Todd Burch,
                                  Congratulations on the quality of that code. To my eye, this is super readable:
                                  var BACKSPACE =  8 ;
                                  var TAB       =  9 ;
                                  var ENTER     = 13 ;
                                  var SHIFT     = 16 ;
                                  Just one question: why the space before the semicolon?
                                  Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                                    driven
                                    hi,
                                    I can't believe it myself, but I now have it working on my Mac...
                                    I changed it to "darwin" in line 137 and he longer falls
                                    	if RUBY_PLATFORM.include?("darwin") then script = "top.GROUNDZ = " + groundZ.to_s + ";"
                                    	else script = "newGroundZ(" + groundZ.to_s + " );" ;
                                    	end ;
                                    	dialog.execute_script(script);
                                    now to see if all else works.....
                                    john
                                      todd burch
                                      @martinrinehart said:
                                      Todd Burch,
                                      Habit. Most languages I code in require a semi colon (C / C++ / Java / Javascript / PL/1 ) and other languages (Ruby, REXX) a semi colon is optional. Just a style I've developed over the last ... 26 years I guess it is now...
                                      Thanks. Todd
                                        Jim
                                        It's been a few years since Scott released this game demo, and I thought there might be a few people who have not seen it, so here it is. bump. I was floored at the time to see this working in SketchUp, but it is still pretty awesome.
                                        There is a link to download the game in the first post of this topic - it works with sketchup 8.
                                        There is a clip in the video showing the game starting at 19m30s, but there's a lot of good developer info in the rest of the video too.
                                        YouTube - Google I/O 2008 - Advanced Ruby Scripting for Sketchup
                                        by GoogleDevelopers
                                        [flash=480,385:22ep2clm]http://www.youtube.com/v/FALvwBN5-hc?fs=1&hl=en_US[/flash:22ep2clm]
                                          <edit>
                                          Too big to upload to the forums, so you can get it here...
                                          http://www.sketchupdemos.com/knightgame.zip
                                          It's about 4mb.
                                          </edit>
                                          Does anyone still have a copy of this file?
                                            tomasz
                                            I do πŸ˜„
                                            Have had to dig through my old backup HD and have found the file.
                                            I liked the idea of a better control over SU.
                                            knightgame.zip
                                            • 2 / 3
