    Prince IO Sketchup Game Demo
    42 Posts 26 Posters 34.7k Views 26 Watching
    • T
      todd burch
      .rb files are merely text files. Notepad, Textedit, lots of editors will work. Always save as plain text.
        August
        ... You can hear more details from the original preso: http://www.youtube.com/watch?v=FALvwBN5-hc
        YouTube says: "We're sorry, this video is no longer available."
        Any alternate sources?
        Thanks,
        August
        β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
        • scottliningerS
          scottlininger
          Hey August,
          I've sent a query to the code site folks asking what happened to the video.
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
          • T
            Trimmer
            Hi Scott,
            I'm Having the same problem BTM did back in Nov:
            I have a mac running OSX 10.5.6, and for every frame, I encounter the error
            %(#808080)["newGroundz:
            value=>-5000<
            TypeError: Value undefined (result of expression value.split) is not object."].
            the error pops up first, i have to click enter, then next frame, same error, this repeat over and over, then the knight falls through the floor, screams, and SU messes up. Any idea why?
            I'll need to test on my Mac with SU7 and post a fixed version.
            Have you found a way to correct this?
              driven
              Hi All,
              did anyone ever get this running on a Mac? can something be changed to make it run?
              • T
                todd burch
                This was working on a Mac back when Scott posted this thread. Did someone or SU break it since then?
                  driven
                  hi Todd,
                  I only downloaded it recently and it appears to have the same symptoms as BTM's early post described, so I thought it had not been fixed....
                  or the solution had moved on to a different thread, as sometimes happens...
                  so, it's not currently working on 7.1 on a Mac and although I'm happy to modify the code, I'd need some instructions.
                  cheers
                  • scottliningerS
                    scottlininger
                    Hmm. Todd's cleaned up version was working on mac. I'll take a look...
                    • Scott Lininger
                      driven
                      Thanks for that...
                        MartinRinehart
                        Todd Burch,
                        Congratulations on the quality of that code. To my eye, this is super readable:
                        var BACKSPACE =  8 ;
                        var TAB       =  9 ;
                        var ENTER     = 13 ;
                        var SHIFT     = 16 ;
                        Just one question: why the space before the semicolon?
                          driven
                          hi,
                          I can't believe it myself, but I now have it working on my Mac...
                          I changed it to "darwin" in line 137 and he longer falls
                          	if RUBY_PLATFORM.include?("darwin") then script = "top.GROUNDZ = " + groundZ.to_s + ";"
                          	else script = "newGroundZ(" + groundZ.to_s + " );" ;
                          	end ;
                          	dialog.execute_script(script);
                          now to see if all else works.....
                          • T
                            todd burch
                            @martinrinehart said:
                            Todd Burch,
                            Habit. Most languages I code in require a semi colon (C / C++ / Java / Javascript / PL/1 ) and other languages (Ruby, REXX) a semi colon is optional. Just a style I've developed over the last ... 26 years I guess it is now...
                            Thanks. Todd
                              Jim
                              It's been a few years since Scott released this game demo, and I thought there might be a few people who have not seen it, so here it is. bump. I was floored at the time to see this working in SketchUp, but it is still pretty awesome.
                              There is a link to download the game in the first post of this topic - it works with sketchup 8.
                              There is a clip in the video showing the game starting at 19m30s, but there's a lot of good developer info in the rest of the video too.
                              YouTube - Google I/O 2008 - Advanced Ruby Scripting for Sketchup
                              by GoogleDevelopers
                              [flash=480,385:22ep2clm]http://www.youtube.com/v/FALvwBN5-hc?fs=1&hl=en_US[/flash:22ep2clm]
                                <edit>
                                Too big to upload to the forums, so you can get it here...
                                http://www.sketchupdemos.com/knightgame.zip
                                It's about 4mb.
                                </edit>
                                Does anyone still have a copy of this file?
                                • T
                                  tomasz
                                  I do πŸ˜„
                                  Have had to dig through my old backup HD and have found the file.
                                  I liked the idea of a better control over SU.
                                  knightgame.zip
                                    JanieStrickland Newcomers
                                    can it be changed in the next update?
                                      Is there any way to fix this?
                                      • 2 / 3
