    Articulation during animation
    14 Posts 4 Posters 1.8k Views 4 Watching
    • Al HartA Offline
      Al Hart
      Form a client:
      *Is it possible to articulate models during animation, to show
      for example blinds coming over windows. Is this possible, if not with
      Irender or standard sketchup, are there any other plugins that will do this?*
      The IRender animation does not do articulation or movement of components. It only replicates the animation in SketchUp.
      It is possible to change the layers at each key frame. So you could walk up to the blinds or a door and have them snap open. But you could not have them open slowly.
      I am posting this query on the SketchUp Community Forum to see if anyone has created a ruby to help with true animation, rather than just a walk through.
      Al Hart
      IRender nXt from Render Plus
        remus
        I think i can think of a way of getting them to open slowly using section cuts. Wouldnt look great, but would probably be ok if you didnt look to closely.
          remus
          Heres quick demo.
          The shutter sections and support bits are all in a group.
          In the 1st scene the section cut at the top of the group is hidden and inactive. Then in the second scene It is hidden but active. You can change the timing by changing the scene transition time (window->model info->animation.)
          blinds animation.skp
          • Al HartA Offline
            Al Hart
            I forgot that you can also put partially open blinds in layers and create about 8 very short key frames showing the blinds opening.
            (I seem to recall that there is a ruby script which lets you assign particular times to key frames)
            Al Hart
            • Al HartA Offline
              Al Hart
              @remus said:
              Heres quick demo.
              Wow - amazing work remus! ☀
              Al Hart
                remus
                Wholehearted borrowing of the idea from someone else, though 😛
                  Dear Remus!
                  Most of the people here having learnt SU by themselves and from the wiser people on the forums, we could (almost) all say this.
                  Knowledge is something very rare (maybe only love is similar): the more you share and give away the more you have.
                    remus
                    youve lost me pilou...
                      For gradually hide all the circle 😄
                        Does it possible to apply the same Section cut Plan Remus'trick at this form?
                          remus
                          Ahhh, i see. Ummm, i dont think it would work. I havent tried it, but as far as im aware the movement of the section planes only works in one direction.
                            the problem is that the Cut section can be revolved but can't be reduced to a part of size! 😞
                            So the circle is trimed from side to side 😮
                            Can make that will be a cool feature!
                            But there is maybe an another trick tip 😄
                            A double double Cut section following with inversed states?
                            Not yet found and some headaches 😆
                              Of course make like Dik here is possible but it's classic and painfull 😉
                                Now I have that 😉
                                Only half of the way 😒
                                headache.skp
