    Articulation during animation
    14 Posts 4 Posters 2.0k Views 4 Watching
    • Al HartA
      Al Hart
      @remus said:
      Heres quick demo.
      The shutter sections and support bits are all in a group.
      In the 1st scene the section cut at the top of the group is hidden and inactive. Then in the second scene It is hidden but active. You can change the timing by changing the scene transition time (window->model info->animation.)
      Wow - amazing work remus! โ˜€
      Al Hart
      IRender nXt from Render Plus
        remus
        Wholehearted borrowing of the idea from someone else, though ๐Ÿ˜›
        • GaieusG
          Dear Remus!
          Most of the people here having learnt SU by themselves and from the wiser people on the forums, we could (almost) all say this.
          Knowledge is something very rare (maybe only love is similar): the more you share and give away the more you have.
            remus
            youve lost me pilou...
              For gradually hide all the circle ๐Ÿ˜„
                Does it possible to apply the same Section cut Plan Remus'trick at this form?
                  remus
                  Ahhh, i see. Ummm, i dont think it would work. I havent tried it, but as far as im aware the movement of the section planes only works in one direction.
                    the problem is that the Cut section can be revolved but can't be reduced to a part of size! ๐Ÿ˜ž
                    So the circle is trimed from side to side ๐Ÿ˜ฎ
                    Can make that will be a cool feature!
                    But there is maybe an another trick tip ๐Ÿ˜„
                    A double double Cut section following with inversed states?
                    Not yet found and some headaches ๐Ÿ˜†
                      Of course make like Dik here is possible but it's classic and painfull ๐Ÿ˜‰
                        Now I have that ๐Ÿ˜‰
                        Only half of the way ๐Ÿ˜’
                        headache.skp
