    Help- how can i draw this 3D (water drop)
    11 Posts 6 Posters 3.9k Views 6 Watching
    • O
      ocean
      this is supposed to be a all round figure. like a water drop.
      • P
        pav_3j
        really sorry but i don't quite understand what you are asking, do you need help modeling this shape?
        oh and for the record water droplets are perfectly spherical.
        he he
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • P
          pav_3j
          sorry, didn't read the thread title properly!
          do you have some drawings from other perspectives, to give more of an idea of the shape.
          cheers
          pav
          • rodrigonotorR
            rodrigonotor
            I think you have to use a ruby call Subdivide and Smooth.
            http://www.smustard.com/script/SubdivideAndSmooth
            Take a look to this post
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=9675&st=0&sk=t&sd=a&hilit=solo+toons
            • Sketchando.net • www.arqcad.net •
            • V
              Voder Vocoder
              ocean,
              This was done using skin.rb. Obviously, the more sections you use, the smoother the contour.
              ~Voder
              droplet.skp
              • O
                ocean
                wow thank you very much!!
                • R
                  remus
                  Heres a quick attempt using subd and smooth, somewhat lacking in elegance though.
                  water drop shape.skp
                  • O
                    ocean
                    Voder,
                    thank you again! but when i tried to do it myself i couln't get to the 4th figure. i have the skin.rb i select the 3rd figure and go to Tools-->skin ....it gives 3 options - clear skin, skin and set settings. i select the 3rd figure and click skin but it doesn't work. what am i doing wrong?
                    • V
                      Voder Vocoder
                      ocean,
                      Just select two adjacent sections (circles) and click the Skin toolbar button. Each circle will be part of two skinning operations as it is joined with its neighbors on either side. If you're using the version that Darrel just uploaded, set the Preferences to:
                      Skin Method: By Distance
                      Prep Method: None
                      Clean: Yes
                      Smooth: --
                      ~Voder
                      • O
                        ocean
                        ok now i got it! thank you for your help!
                        • pbacotP
                          Voder,
                          Your excellent example gave me an idea. Wouldn't it be great to have a ruby to do the first part of your example. It seems logical enough. Two shapes: divide the first one in sections. Create a scaled slice with the second shape... Could this be done. It could even skin it for you afterwards.
                          Peter
