    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] DoorTool starter
    18 Posts 13 Posters 19.7k Views 13 Watching
      tomot
      I'm currently developing a DoorTool, which will work in a similar fashion to my WindowTool
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12869
      This tool will contain both a Right and Left Hand door sub menu. You will also be able to create Right and Left Hand Reverse doors from the same side of the opening. And as in WindowTool I intend to break out separate door items such as hardware, door frame, door trim, louvers, and solid panels, and glass panels. In addition Door Styles and Rails will also be adjustable.
      The doors will automatically be placed on a door layer and the door swing arc (which is not an arc yet) will be placed on the a doorswing layer. I'm currently releasing the DoorToolRight.rb ONLY, to see if their is any interest in this ruby. The remaining rubies for adding frames, trim, louvers, grilles, and icon bar will come later depending on the response.
      example of some of the various types of doors, DoorTool is capable of producing
      DoorToolRight.rb
      my plugins
      tomot
      • CadFatherC Offline
        CadFather
        Tomot Thanks, these tools are great indeed! ๐Ÿ‘
          seasdes
          Tomot
          Thaks a lot. I would find this rubie very useful - especially if you develop it further as you suggested.
          Walter ๐Ÿ˜
          Using Sketchup Pro 2019
            Doors! A famous group ๐Ÿ˜‰
              Dan
              Very useful script, at least for me.
              Thanks a lot, tomot!
              And, of course, as an architect, I'll be more than happy to have such a nice tool.
              Keep up the good work!
              Dan
              • utilerU Offline
                utiler
                great work mate!!!
                Just Curious...
                  Mr S
                  Considering how valuable the Windowizer tool has been it seems strange on reflection that the same hasn't been done for doors long ago.
                  This will be a really helpful tool.
                  I look forward to the the completed project.
                  Thanks for taking the time out to provide yet another valuable tool.
                  (The guys at Google are going to have to come with something special for SketchUp 7. The Ruby guys keep racing ahead with new ideas!)
                  Regards
                  Mr S
                    bubbalove
                    Thanks a bunch... please do keep working on this tool. In time... it will be just as useful as the windowizer!
                    "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                    • MALAISEM Offline
                      MALAISE
                      Thanks for work done on this plugin ๐Ÿ‘
                      go ahead...
                      MALAISE ๐Ÿ‘ ๐Ÿ‘
                      La Connaissance n'a de valeur que partagรฉe
                      • Didier BurD Offline
                        Didier Bur
                        Hi Tomot,
                        Great tool.
                        Let me add my 2 cts about the code:
                        As I made a lot of mistakes myself in my scripts, I know how it is frustrating when you release a script and that it may corrupts other scripts at the user end. You use many globals (such as $pts,$ip, etc).
                        I suggest you use instance variables or class variables instead such as @pts, @ip,etc). This way you prevent your variables to overwrite other variables of the same name in other scripts.
                        class DoorToolRight
                        def initialize
                            $ip = Sketchup;;InputPoint.new
                            $ip1 = Sketchup;;InputPoint.new
                            reset
                            # sets the default Door settings
                            $dwthick = 6.0. inch if not $dwthick            # door frame/wall thickness
                            $rdfthick = 0.0. inch if not $rdfthick
                        Could be:
                        class DoorToolRight
                        def initialize
                            @ip = Sketchup;;InputPoint.new
                            @ip1 = Sketchup;;InputPoint.new
                            reset
                            @dwthick = 6.0. inch if not @dwthick            # door frame/wall thickness
                            @rdfthick = 0.0. inch if not @rdfthick
                        These variables are "readable" by all the methods of the class, but "live" only when the tool object lives. This is safer...
                        DB
                        • utilerU Offline
                          utiler
                          tomot, it doesn't appear that the script cuts a plane through the wall; am i right?
                          see attached.
                          cheers,
                          Just Curious...
                            tomot
                            see attached.
                            cheers,
                            It works in the same way WindowTools works.
                            Think about how Windows and Doors are installed into openings in typical Western Frame Construction.
                            The Framer or Carpenter must first define or build the opening, into which the window or door is to be installed. In the same way you must provide the opening in a wall in SU first into which the door or window will be installed.
                            Furthermore the opening in a wall is also related to the Wall Thickness. If your walls are of a predefined thickness other than the default 6" then you must change the thickness in the dialog box to reflect your wall thickness.
                            You only want to use my window or door tool if you want to create objects , where your design will be rendered or seen from both inside or outside. If you are concerned only about rendering the exterior view then you could use Windowizer.
                            my plugins
                            tomot
                              tomot
                              @didier bur said:
                              Hi Tomot,
                              Thank you Didier for your comments. I should have been more careful. I mistakenly posted my development
                              version, in which I need globals so I can check the values in the console.
                              my plugins
                              tomot
                                Ben Ritter
                                Tomot, I appreciate your efforts and looks like it has great possiblities. My main suggestion is that the hardware should include lever style handles. Also, what about solid wood doors, or did I miss something?
                                Ben
                                • jim smithJ Offline
                                  jim smith
                                  Tom,
                                  Thanks for taking the time to create the door.rb.
                                  I have used DoorMaker.rb by PKR but your routine looks like it will give a few more options when your done. You might look at doormaker.rb if you haven't already, there are quite a few good features in it like the four door swings on different layers.
                                  Thanks again - please keep working on this tool - I will look for the updates โ˜€
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                    tomot
                                    Tom,
                                    Jim I have looked at Doormaker. That's why I'm trying hard to provide an equally, competent, alternative.
                                    I can see where PKR derived his/her approach, its much more technical and institutional, in nature.
                                    I wanted to maintain and stay on the residential side of doors. I'm not intending to include kick plates
                                    hinges, or dbl sided rebated frames, in steel or wood. There is obviously an unlimited amount one can or should not
                                    show on drawing, and that's where a Door Schedule and Specification normally take over.
                                    my plugins
                                    tomot
                                      tomot
                                      @ben ritter said:
                                      Tomot, My main suggestion is that the hardware should include lever style handles. Also, what about solid wood doors, or did I miss something? Ben
                                      Thanks Ben I will attempt a lever option. Although you are well aware you opening up a very large can of worms
                                      when we are starting to talk about door accessories ๐Ÿ˜„ The solid wood door is what in the drop down menu I call
                                      a Slab door.
                                      my plugins
                                      tomot
                                        cyan.archnet
                                        very HELPFUL and HANDY plugin!, THANKS A LOT!
