    [Plugin] DoorTool starter
    18 Posts 13 Posters 20.6k Views 13 Watching
    • MALAISEM
      MALAISE
      Thanks for work done on this plugin 👍
      go ahead...
      MALAISE 👍 👍
      • Didier BurD
        Didier Bur
        Hi Tomot,
        Great tool.
        Let me add my 2 cts about the code:
        As I made a lot of mistakes myself in my scripts, I know how it is frustrating when you release a script and that it may corrupts other scripts at the user end. You use many globals (such as $pts,$ip, etc).
        I suggest you use instance variables or class variables instead such as @pts, @ip,etc). This way you prevent your variables to overwrite other variables of the same name in other scripts.
        class DoorToolRight
        def initialize
            $ip = Sketchup;;InputPoint.new
            $ip1 = Sketchup;;InputPoint.new
            reset
            # sets the default Door settings
            $dwthick = 6.0. inch if not $dwthick            # door frame/wall thickness
            $rdfthick = 0.0. inch if not $rdfthick
        Could be:
        class DoorToolRight
        def initialize
            @ip = Sketchup;;InputPoint.new
            @ip1 = Sketchup;;InputPoint.new
            reset
            @dwthick = 6.0. inch if not @dwthick            # door frame/wall thickness
            @rdfthick = 0.0. inch if not @rdfthick
        These variables are "readable" by all the methods of the class, but "live" only when the tool object lives. This is safer...
        DB
        • utilerU
          utiler
          tomot, it doesn't appear that the script cuts a plane through the wall; am i right?
          see attached.
          cheers,
          Just Curious...
          • T
            tomot
            see attached.
            cheers,
            It works in the same way WindowTools works.
            Think about how Windows and Doors are installed into openings in typical Western Frame Construction.
            The Framer or Carpenter must first define or build the opening, into which the window or door is to be installed. In the same way you must provide the opening in a wall in SU first into which the door or window will be installed.
            Furthermore the opening in a wall is also related to the Wall Thickness. If your walls are of a predefined thickness other than the default 6" then you must change the thickness in the dialog box to reflect your wall thickness.
            You only want to use my window or door tool if you want to create objects , where your design will be rendered or seen from both inside or outside. If you are concerned only about rendering the exterior view then you could use Windowizer.
            my plugins
            tomot
            • T
              tomot
              @didier bur said:
              Hi Tomot,
              Thank you Didier for your comments. I should have been more careful. I mistakenly posted my development
              version, in which I need globals so I can check the values in the console.
              my plugins
              tomot
              • B
                Ben Ritter
                Tomot, I appreciate your efforts and looks like it has great possiblities. My main suggestion is that the hardware should include lever style handles. Also, what about solid wood doors, or did I miss something?
                Ben
                • jim smithJ
                  jim smith
                  Tom,
                  Thanks for taking the time to create the door.rb.
                  I have used DoorMaker.rb by PKR but your routine looks like it will give a few more options when your done. You might look at doormaker.rb if you haven't already, there are quite a few good features in it like the four door swings on different layers.
                  Thanks again - please keep working on this tool - I will look for the updates ☀
                  "Out of clutter find simplicity,
                  from discord find harmony,
                  In the middle of difficulty lies opportunity"
                  Albert Einstein
                  • T
                    tomot
                    Tom,
                    Jim I have looked at Doormaker. That's why I'm trying hard to provide an equally, competent, alternative.
                    I can see where PKR derived his/her approach, its much more technical and institutional, in nature.
                    I wanted to maintain and stay on the residential side of doors. I'm not intending to include kick plates
                    hinges, or dbl sided rebated frames, in steel or wood. There is obviously an unlimited amount one can or should not
                    show on drawing, and that's where a Door Schedule and Specification normally take over.
                    my plugins
                    tomot
                    • T
                      tomot
                      @ben ritter said:
                      Tomot, My main suggestion is that the hardware should include lever style handles. Also, what about solid wood doors, or did I miss something? Ben
                      Thanks Ben I will attempt a lever option. Although you are well aware you opening up a very large can of worms
                      when we are starting to talk about door accessories 😄 The solid wood door is what in the drop down menu I call
                      a Slab door.
                      my plugins
                      tomot
                      • C
                        cyan.archnet
                        very HELPFUL and HANDY plugin!, THANKS A LOT!
