    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 39.9k Views 13 Watching
    • CadFatherC Offline
      CadFather
      is it possible to define an action (by icon or shortcut key) which unsoftens a selection in one go without having to go to smooth/soften and move the slider all the way down?
      and is the reverse (one click soften)?
      SOLVED - PLUGIN CREATED BY MATT
      PLEASE USE THIS LINK FOR THE MOST RECENT VERSION
      [file contains script and folder with icons - drop both into the plugins directory]
      Soften.zip
      • PixeroP Offline
        Pixero
        If I remember correct this free plugin has it: http://www.cadspan.com/tools
          Matt666
          A script was created to do what you want, here !
          Frenglish at its best !
          My scripts
            CadFather
            THANKS GUYS!!!
            Pixero for a new interesting plugin
            Matt for a genius 'back to the future plugin' - works just great even for groups and all!
            (and it's much easier for quick smooth/unsmooth)
            will see if i can create a toolbar to the commands..
              Matt666
              This plugin will help someone, finally... 😄
              As always, great icons CadFather !
              My scripts
                CadFather
                Thanks Matt - and i even learned how to create toolbar items (by copying Jim's scripts).. 😄
                • ___olo_ Offline
                  ___olo
                  CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
                  Xin chào nhau giữa con đường
                  Mùa xuân phía trước, miên trường phía sau
                    CadFather
                    done - look up for new download
                      CadFather
                        chango70
                        Wow this answered my prayers!
                        • W Offline
                          watkins
                          Dear Matthieu,
                          I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
                          Kind regards,
                          Bob
                            CadFather
                            Bob, you need both the plug in and the folder called smooze (with the icons)
                            • W Offline
                              watkins
                              Dear CadFather,
                              Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
                              Kind regards,
                              Bob
                              • W Offline
                                watkins
                                Dear Matthieu and Cadfather,
                                I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
                                Regards,
                                Bob
                                  Matt666
                                  Hi CadFather !
                                  I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
                                  So now you've got three tools :
                                  Mildly Soft edges
                                  Completely Soft edges
                                  Unsoft edges
                                  You forgot a bit of code at the end...
                                  if (not file_loaded?("Soften.rb"))
                                  Now the tool will be loaded just one time !
                                  and the code is also changed following the RickW notices (I hope 😉 )
                                  Good luck for the next icon 😄
                                  EDIT : Version 1.1
                                  Soften.rb
                                  My scripts
                                    CadFather
                                    will post a working final version from Matt very soon - need to finish a couple of things first.
                                    Bob, yes one of those... 😉
                                      CadFather
                                      Hi Matt, i have a problem with the new version: nothing happens 😕
                                      still works with the old one
                                      i have updated the script with the 3 icons (changed the name for the new command icon)
                                        CadFather
                                        small update for whoever likes this idea:
                                        tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
                                        (i removed menus in plugins)
                                        now it is a quick step!
                                        Thanks Matt! 👍
                                        • W Offline
                                          watkins
                                          Thanks!
                                          • P Offline
                                            publied
                                            oh my hero, my savior! this plugin is very useful for me! thanks!
                                            hire me@ http://www.publied.it !
                                            • 2 / 2
