    How to put a small image on a bottle
    14 Posts 5 Posters 3.8k Views 5 Watching
    • P
      PRSS
      Hello everybody!
      Please tell me how to put a small image, say 3 inches square on a large bottle as a label.
      I do not want the image to be tiled on the bottle nor do I want the image to fully wrap
      around the whole bottle. It should be a patch on the curved surface of the bottle. Is this
      possible?
      One way is to actually put another surface itself to the size I wanted on the bottle and
      apply the image on this surface. But I was wondering if there was another way.
      Thanks in advance
      PRSS
      • R
        remus
        Hopefully this tut will be of some use.
        projected texture tut.skp
        • P
          PRSS
          Thank you Remus for the quick reply. But this doesn't help in this case.
          with best regards
          PRSS
          • GaieusG
            Then here is another solution.
            Go through the scenes
            • soloS
              solo
              easy label
              easy label.skp
              http://www.solos-art.com
              • GaieusG
                Neee, Pete, that's "lazy" label! πŸ˜„
                • soloS
                  solo
                  admittedly it is ... but wine does that to me.
                  • V
                    Voder Vocoder
                    Using a projected image can result in undesirable distortion, so here's another method that wraps the image instead of projecting it.
                    ~Voder
                    alfred.skp
                    • GaieusG
                      True, it can distort on the sides and it's especially noticeable if you want to cover a considerable amount of the curve.
                      I used the same "segment length count" for an example in an old forum topic - see the file here.
                      • V
                        Voder Vocoder
                        That's pretty nice, Gaieus. What the heck is it?
                        ~V
                        • GaieusG
                          Nothing special - just the illustration of this wrapping technique; how you can do it without cropping the image (too big image size) or tiling it (too small image size).
                          That was still for a discussion over the Help Groups and the "text" was provided in the post.
                          • P
                            PRSS
                            Hello everybody!
                            Thank you Gaieus, Solo and Voder. I am overwhelmed by the replies.
                            These have been very helpful to me. I did not quite understand Solo's
                            method. And Voder has said about unsmoothing the line. How do you
                            do that?
                            Thanks once again
                            PRSS
                            • V
                              Voder Vocoder
                              @prss said:
                              Voder has said about unsmoothing the line. How do you do that?
                              Unsmooth (or unhide) = Ctrl-Shift-Eraser. You can also just select the smoothed line and move the slider on the Smooth/Soften dialog all the way to the left. You'll want to display hidden geometry while you do this so you can see what you're doing.
                              ~Voder
                              • P
                                PRSS
                                Thank you very much Voder
                                With best regards
                                PRSS
