    How to put a small image on a bottle
    14 Posts 5 Posters 3.7k Views 5 Watching
      PRSS
      Thank you Remus for the quick reply. But this doesn't help in this case.
      with best regards
      PRSS
        Then here is another solution.
        Go through the scenes
        • soloS Offline
          easy label
          easy label.skp
            Neee, Pete, that's "lazy" label! πŸ˜„
            • soloS Offline
              admittedly it is ... but wine does that to me.
              • V Offline
                Voder Vocoder
                Using a projected image can result in undesirable distortion, so here's another method that wraps the image instead of projecting it.
                ~Voder
                alfred.skp
                  True, it can distort on the sides and it's especially noticeable if you want to cover a considerable amount of the curve.
                  I used the same "segment length count" for an example in an old forum topic - see the file here.
                  • V Offline
                    Voder Vocoder
                    That's pretty nice, Gaieus. What the heck is it?
                    ~V
                      Nothing special - just the illustration of this wrapping technique; how you can do it without cropping the image (too big image size) or tiling it (too small image size).
                      That was still for a discussion over the Help Groups and the "text" was provided in the post.
                        PRSS
                        Hello everybody!
                        Thank you Gaieus, Solo and Voder. I am overwhelmed by the replies.
                        These have been very helpful to me. I did not quite understand Solo's
                        method. And Voder has said about unsmoothing the line. How do you
                        do that?
                        Thanks once again
                        PRSS
                        • V Offline
                          Voder Vocoder
                          @prss said:
                          Voder has said about unsmoothing the line. How do you do that?
                          Unsmooth (or unhide) = Ctrl-Shift-Eraser. You can also just select the smoothed line and move the slider on the Smooth/Soften dialog all the way to the left. You'll want to display hidden geometry while you do this so you can see what you're doing.
                          ~Voder
                            PRSS
                            Thank you very much Voder
                            With best regards
                            PRSS
