    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.2m Views 183 Watching
    • S
      surfmike
      What will the difference be between the 2 options?
      • fredo6F
        fredo6
        That's not the same curve, but visually, with hundreds of points, they may look the same!
        Fredo
        • M
          Medvezhonok
          Please update BezierSpline signature for compatibility with SU 2017
          • fredo6F
            fredo6
            NEW RELEASE 1.9a - 12 Feb 17
            This release is certified for Sketchup 2017
            Download new release at main post
            Fredo
            • T
              trngngntn
              Great plugin !!!
              Btw can you do B-spline through points like this one :
              https://extensions.sketchup.com/en/content/b-spline-curves-through-points
              • fredo6F
                fredo6
                In BezierSpline, you have several tools to have the curve go thorugh the control points: Cubic BSpline, Catmull, FSpline.
                Fredo
                • T
                  trngngntn
                  Fredo
                  I tried these tools but I feel that not what I needed.
                  The begin and the end of the curves look too flat.
                  F Spline is better but still flat.
                  I included an image here :
                  https://i.imgur.com/t65T7K7.png
                  The curve which generated by the B Spline through points look smoother, but that plugin is hard to use and lack of editing tools.
                  So I hope you can add that to yours.
                    Fredo doesn't need to add editing tools to this extension. You can already edit the curves created with it.
                    • T
                      trngngntn
                      No, I mean that I hope he can add that type of curve to his plugin !!
                      • T
                        trngngntn
                        I have some trouble when editing the curves.
                        I drew a curve in Side view
                        https://i.imgur.com/rTEsVsG.png
                        The I switch to Top view to edit control points
                        https://i.imgur.com/It75S7J.png
                        But when I back to Side view, the curve changed a lot !!
                        https://i.imgur.com/ggsfQJM.png
                        So, how can I move the control points along a specified axis (X, Y, Z)?
                        Thanks.
                          If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle. Or, you can set the camera to Parallel Projection and selected the appropriate standard view befor editing the curve. I like the large face option myself.
                          • robertWanR
                            robertWan
                            @dave r said:
                            If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle....
                            Or use the plugin WorkPlane.
                            Robert
                            • J
                              jayaha5
                              thank you
                              • R
                                raguenther56
                                I am using v1.9 with Sketchup Make 2017 on a Mac. Some of the curves do not allow me to edit them after being created. After selecting the curve, with a right-click I get the standard menu items and not the editing options. Some curves work and some don't. I've seen this with the Cubic Bezier Curve and Catmull Spline. It appears to have something to do with the number of control points. Simple curves and its OK. Curves with more control points and I loose the edit function. Any suggestions?
                                  Share an example SKP file showing a curve that you can't edit.
                                  • fredo6F
                                    fredo6
                                    Be careful that a contour generated by BezierSpline must remain a Sketchup Curve to be editable. If you cut it by another edge intersection or explode it, it won't remind that it was created by BezierCurve.
                                    As Dave said, maybe it's best to post a sample model where you have the problem.
                                    Fredo
                                    • R
                                      raguenther56
                                      Curve on right is OK. Curve on left I can't edit. Both were made using Cubic Bezier Curve with precision set to 20.
                                      Sample.skp
                                      • R
                                        raguenther56
                                        I did some additional experiments. Drew a simple curve with Cubic Bezier Curve that I was able to edit. From there I added control points one at a time while editing. Once I got to 24 control points (not counting the two end points), I could no longer edit the curve. A right-click gave me the standard menu selections.
                                        The attached file has two curves. The one on the right can be edited. The one on the left is a copy of the right curve, but one more control point has been added. It is no longer editable.
                                        Sample 2.skp
                                        • fredo6F
                                          fredo6
                                          Thanks for signaling.
                                          Actually, it is not related to the number of control points but to the number of edges of the curve.
                                          For whatever reasons, there was a limitation to 500.
                                          I will republish without the limitation.
                                          Fredo
                                          • fredo6F
                                            fredo6
                                            NEW RELEASE 1.9b - 25 Feb 18
                                            This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
                                            Fredo
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
