    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      @trngngntn said:
      and lack of editing tools.
      So I hope you can add that to yours.
      Fredo doesn't need to add editing tools to this extension. You can already edit the curves created with it.
      • T
        trngngntn
        No, I mean that I hope he can add that type of curve to his plugin !!
        • T
          trngngntn
          I have some trouble when editing the curves.
          I drew a curve in Side view
          https://i.imgur.com/rTEsVsG.png
          The I switch to Top view to edit control points
          https://i.imgur.com/It75S7J.png
          But when I back to Side view, the curve changed a lot !!
          https://i.imgur.com/ggsfQJM.png
          So, how can I move the control points along a specified axis (X, Y, Z)?
          Thanks.
            If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle. Or, you can set the camera to Parallel Projection and selected the appropriate standard view befor editing the curve. I like the large face option myself.
            • robertWanR
              robertWan
              @dave r said:
              If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle....
              Or use the plugin WorkPlane.
              Robert
                jayaha5
                thank you
                  raguenther56
                  I am using v1.9 with Sketchup Make 2017 on a Mac. Some of the curves do not allow me to edit them after being created. After selecting the curve, with a right-click I get the standard menu items and not the editing options. Some curves work and some don't. I've seen this with the Cubic Bezier Curve and Catmull Spline. It appears to have something to do with the number of control points. Simple curves and its OK. Curves with more control points and I loose the edit function. Any suggestions?
                    Share an example SKP file showing a curve that you can't edit.
                    • fredo6F
                      Be careful that a contour generated by BezierSpline must remain a Sketchup Curve to be editable. If you cut it by another edge intersection or explode it, it won't remind that it was created by BezierCurve.
                      As Dave said, maybe it's best to post a sample model where you have the problem.
                        raguenther56
                        Curve on right is OK. Curve on left I can't edit. Both were made using Cubic Bezier Curve with precision set to 20.
                        Sample.skp
                          raguenther56
                          I did some additional experiments. Drew a simple curve with Cubic Bezier Curve that I was able to edit. From there I added control points one at a time while editing. Once I got to 24 control points (not counting the two end points), I could no longer edit the curve. A right-click gave me the standard menu selections.
                          The attached file has two curves. The one on the right can be edited. The one on the left is a copy of the right curve, but one more control point has been added. It is no longer editable.
                          Sample 2.skp
                          • fredo6F
                            Thanks for signaling.
                            Actually, it is not related to the number of control points but to the number of edges of the curve.
                            For whatever reasons, there was a limitation to 500.
                            I will republish without the limitation.
                            • fredo6F
                              NEW RELEASE 1.9b - 25 Feb 18
                              This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
                              Download new release at main post
                                raguenther56
                                Thanks! The update works great. I love this tool as I would not be able to do what I want without it.
                                • E
                                  Einstein
                                  Please, in the next release, make "Redo last change" to quickly compare changes when editing control points.
                                    sashagas
                                    Hello!! Tell me why I can not install the plugin
                                    BezierSpline 1.9a. It does not appear on the toolbar, although it is installed. I can not understand what's the matter, the side plugins work.[img][img][img][img][/img][/img][/img][/img]
                                    • cottyC
                                      cotty
                                      LibFredo is installed too?
                                      my SketchUp gallery
                                      • E
                                        Einstein
                                        Right-click on free space in your toolbar and check if there's BezierSpline in the drop-down list. If so, check it. If not, restart SketchUp or even your computer and check again. If it still doesn't work then I don't know.
                                        • fredo6F
                                          NEW RELEASE 1.9c - 31 Jul 18
                                          This release fixes issues related to non-ascii Windows usernames.
                                          More info at main post
                                          Download BezierSpline at Sketchucation Plugin Store
                                          • fredo6F
                                            NEW RELEASE 2.0a - 01 Aug 18
                                            This release fixes other issues related to non-ascii Windows usernames.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
