    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      trngngntn
      I have some trouble when editing the curves.
      I drew a curve in Side view
      https://i.imgur.com/rTEsVsG.png
      The I switch to Top view to edit control points
      https://i.imgur.com/It75S7J.png
      But when I back to Side view, the curve changed a lot !!
      https://i.imgur.com/ggsfQJM.png
      So, how can I move the control points along a specified axis (X, Y, Z)?
      Thanks.
        If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle. Or, you can set the camera to Parallel Projection and selected the appropriate standard view befor editing the curve. I like the large face option myself.
        • robertWanR Offline
          robertWan
          @dave r said:
          If you want to keep the curve in 2D, it's best if you start out by drawing it on a large rectangle....
          Or use the plugin WorkPlane.
          Robert
            jayaha5
            thank you
              raguenther56
              I am using v1.9 with Sketchup Make 2017 on a Mac. Some of the curves do not allow me to edit them after being created. After selecting the curve, with a right-click I get the standard menu items and not the editing options. Some curves work and some don't. I've seen this with the Cubic Bezier Curve and Catmull Spline. It appears to have something to do with the number of control points. Simple curves and its OK. Curves with more control points and I loose the edit function. Any suggestions?
                Share an example SKP file showing a curve that you can't edit.
                • fredo6F Offline
                  Be careful that a contour generated by BezierSpline must remain a Sketchup Curve to be editable. If you cut it by another edge intersection or explode it, it won't remind that it was created by BezierCurve.
                  As Dave said, maybe it's best to post a sample model where you have the problem.
                    raguenther56
                    Curve on right is OK. Curve on left I can't edit. Both were made using Cubic Bezier Curve with precision set to 20.
                    Sample.skp
                      raguenther56
                      I did some additional experiments. Drew a simple curve with Cubic Bezier Curve that I was able to edit. From there I added control points one at a time while editing. Once I got to 24 control points (not counting the two end points), I could no longer edit the curve. A right-click gave me the standard menu selections.
                      The attached file has two curves. The one on the right can be edited. The one on the left is a copy of the right curve, but one more control point has been added. It is no longer editable.
                      Sample 2.skp
                      • fredo6F Offline
                        Thanks for signaling.
                        Actually, it is not related to the number of control points but to the number of edges of the curve.
                        For whatever reasons, there was a limitation to 500.
                        I will republish without the limitation.
                        • fredo6F Offline
                          NEW RELEASE 1.9b - 25 Feb 18
                          This release increases the maximum number of points in curves, even if it is not advised to have too many points in a curve.
                          Download new release at main post
                            raguenther56
                            Thanks! The update works great. I love this tool as I would not be able to do what I want without it.
                            • E Offline
                              Einstein
                              Please, in the next release, make "Redo last change" to quickly compare changes when editing control points.
                                sashagas
                                Hello!! Tell me why I can not install the plugin
                                BezierSpline 1.9a. It does not appear on the toolbar, although it is installed. I can not understand what's the matter, the side plugins work.[img][img][img][img][/img][/img][/img][/img]
                                • cottyC Offline
                                  cotty
                                  LibFredo is installed too?
                                  my SketchUp gallery
                                  • E Offline
                                    Einstein
                                    Right-click on free space in your toolbar and check if there's BezierSpline in the drop-down list. If so, check it. If not, restart SketchUp or even your computer and check again. If it still doesn't work then I don't know.
                                    • fredo6F Offline
                                      NEW RELEASE 1.9c - 31 Jul 18
                                      This release fixes issues related to non-ascii Windows usernames.
                                      More info at main post
                                      Download BezierSpline at Sketchucation Plugin Store
                                      • fredo6F Offline
                                        NEW RELEASE 2.0a - 01 Aug 18
                                        This release fixes other issues related to non-ascii Windows usernames.
                                          delandc
                                          Just what I was looking for. I'm having some issues with a few of the tools. I'm in Sketchup Make 2017 and the polyline arc corners is acting odd. I click the first couple of points and then the whole line vanishes. Uniform b-spline... same. Thoughts?
                                            autumnwind
                                            Hi Fredo, thanks so much for your plugins, they are incredible.
                                            I particularly like Bezier Spline, but I have a problem: I absolutely cannot control the "control points" when I decide to move them along the axis.
                                            I'm working on a uniform spline, a press CTRL and then the desired arrow for the axis direction, then when I drag the point with the mouse, even a super small movement makes the point go super far. Moreover, when I move along the axis, in reality the points sticks to other points in the drawing instead of just moving along the axis. Is there any solution to this?
                                            I hope I was clear. Thanks in advance.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
