    Question about my sketchup model
    8 Posts 5 Posters 1.5k Views 5 Watching
    • T
      Tonto
      Hi everyone.
      I have a bit of experience with sketchup and I have made complete models before in sketchup.
      The thing is, this time the model I am planning on creating has a lot of curves and domes.
      Here's my actual sketch, sorry for the lined paper and messiness, it was a quick brainstorm sketch:
      http://i96.photobucket.com/albums/l200/prashanna/DSC00401copy.jpg
      The lower portion is based on this museum by Santiago Calatrava:
      http://i96.photobucket.com/albums/l200/prashanna/calatrava.jpg
      I have a few questions, could someone please provide me with some advise on how I can achieve these sort of curves? Also, I am okay with making a perfect circle dome, but I am unsure on how to make an oval dome. Also any advise on the columns/pillars.
      Any advise, tutorials/links that relate to this style, help, or anything would be greatly appreciated.
      • A
        AndriyG81
        an oval dome can be created by using scale tool on a round dome. Columns seem to be strait forward. Bu it hard to tell all of your intentions just a sketch.
        If you like you can brake down your model into parts, and do a little sketch of every part, I would be more then happy to assist you. Even do a couple of tutorials.
        http://andriyg.com
        • T
          Tonto
          Oh thanks for the tip on making an oval dome. That helped a lot.
          Also thanks for your offer to help me, that would be great, tomorrow I will sketch the few parts that I need help on.
          • R
            remus
            If your model doesnt need to be too accurate you might have some luck with the FFD tool: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6029&hilit=+Plugin&start=0
            • D
              dylan
              You will certainly need one or two Rubies to help with I guess.
              Soap Skin Bubble
              Joint Push Pull
              From Contours on the Sandbox Tools could help.
              FFD as Remus mentioned
              These are just a few suggestions. You could use more, none or totally different ones.
              http://dmdarchitecture.co.uk/
              • T
                Tonto
                Soap Skin Bubble
                Joint Push Pull
                Thanks, those all look really helpful, I'll try them out.
                • Wo3DanW
                  Wo3Dan
                  Tonto,
                  Your question reminds me of this thread (jan2008):
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=6890&p=44775&hilit=+wo3dan#p44775
                  Maybe it will help you in any way.
                  Wo3Dan
                  • T
                    Tonto
                    @wo3dan said:
                    Tonto,
                    Wo3Dan
                    Thanks for that.
