    SketchUp Thumbnails not showing up?
    30 Posts 16 Posters 23.4k Views 16 Watching
      When you use the Open file dialog in SU you will be able to see thumbnails as SU is a 32bit app. Ok workaround - instead of using the Explorer to locate the files?
      • AnssiA Offline
        Anssi
        XNView is a free image browser software that could display previews for SU files even before SU had the feature itself. Mine is old and it wouldn't do it for recent SU files, but there seems to be a newer one. Has anyone tried it with a 64-bit OS?
        Anssi
          bmunsell
          Hey thanks, it worked for me also except I had to change to sketchup 8 folder. By the way the "cd" stands for change directory and comes from the old dos commands
          • brodieB Offline
            brodie
            Anssi
            The latest Xnview does show thumbnails (I'm on Win7). There's also mysticthumbs http://mysticcoder.net/mysticthumbs.html small fee but it works in explorer which is really handy.
            -brodie
            • N Offline
              nicolerouillard
              Hey,
              This is all very interesting. Having trouble navigating to system32. This is the screen I get:
              • AnssiA Offline
                Anssi
                @nicolerouillard said:
                Hey,
                You are not giving the system any commands. Typing directory names is not enough - as the error message you get shows.
                So you should type, followed by Enter (not the explanations I italicized)
                cd\ (this navigates to the root directory of the current drive)
                cd "c:\Program Files\Google\Google SketchUp 8" (this navigates to the SU application folder, the quotes are compulsory here)
                regsvr32 thumbsup.dll
                Note that this doesn't work if you have a 64-bit operating system.
                Anssi
                  SpookyChick1013
                  Thank you SO much Anssi! I haven't used dos commands in so many years I had forgotten critical little points like those you mentioned, and was struggling with implementing that fix, until I read your post. Now, I will have my thumbnails back, thank the Force!
                  Cathryn
                  https://kuromatsudriveyards.com
                  Fo-su to tomo ni aran koto o...
                  • vyctortumbuanV Offline
                    vyctortumbuan
                    Hello...people.
                    what should i do to fix this?? i was try to follow on the top solution,but im still having a problem.
                      Doesn't work on 64bit systems.
                      http://sketchucation.com/forums/viewtopic.php?f=15&t=13097&view=unread#p218683
                      You can use a third party utility such as MagicThumbs to get thumbnails for 64bit systems + huge number of other formats.
                        vyctortumbuan
                        Thanks Thom.
                        • 2 / 2
