    Help Me! I can 't see the textures in render
    renderpluginsextensions
    4 Posts 4 Posters 1.5k Views 4 Watching
    • G
      Gongax
      Good afternoon, I am typing in Portugal, I performed work in 3D, where the use Sketchup + V-Ray to make renders, until you can see my work in htto: / / archidesign.webnode.com, and now I am with a serious problem when I apply the material they appear, but in the render olny appear the color ... if it calls red brick, so I everything appears red in the final result ... and gives a window of error that says: Failed to create a temporary file name (error 80: the file exists.)
      Please help me.
      Thank you
      • S
        ScottPara
        What version are you using? Have you contacted the Vray forum? Can you post the file? I can take a look at it for you and see what is going on.
        Scott
        Love the fact that some HATE my avatar.....
        • plot-parisP
          plot-paris
          my first guess would be, that you applied the texture to a group. however, like that V-Ray gets no UV coordinates for the texture and therefore shows an average colour instead of the material.
          try to apply the texture right onto the geometry and not outside a group. I think that should solve your problem
          • thomthomT
            Also, if you applied a tga file, which SU supports, V-Ray will only render the diffuse colour because it doesn't support that format.
