    SketchUp Nurbs
    41 Posts 19 Posters 33.9k Views 19 Watching
    • plot-parisP Offline
      plot-paris
      well, NURBS means "Non-uniform rational B-spline" and fredo's bezier curves are splines. I guess, that soapskin bubble works in a similar way.
      as far as I know they both use mathematical algorythms like nurbs and later transform it into polygons.
      so just imagine what our ruby-geeks can come up with if you give them a SketchUp that is solely based on nurbs!
      I have something in mind, where I don't know, if it already exists and I saw it somewhere or if it is my own idea:
      Imagine you create a curved surface in SUN, calculated with nurbs technique. it is supposed to be a rocky, uneven ground. you could apply a material with displacement map, that creates the rough surface during the render process. but you want to see the result while modelling, perhaps even interact with the uneven surface. instead of modelling it yourself, you apply a displacement filter preset to the surface, that recalculates the whole surface, because it is a nurbs element, you don't have to translate it to polygons every time you make a change.
      thus you can easily change the overall shape by manipulating the original curves of the surface, while the displacement filter will adopt to the changes.
      http://img159.imageshack.us/img159/2617/displacementfilterjd9.jpg
        chango70
        ๐Ÿ˜ฒ Sounds great! I'd imagine whoever can do this and indeed does it should get paid.
          chango70
          Isn't Bezier Curve and Bubble Skin script able to approximate Nurb Modelling?
            minguinhirigue
            This is quite a big idea, but implicit geometry (NURBS, Blobs, and other forms that could be redraw from control points, lines and faces) is really far from what sketchup is doing today. However, there are a lot of soft which are actually doing what you are talking about :
            • Rhino 3D
            • Moi 3D
            • Bonzai 3D soon
            But, I recognize that Sketchup interface is easer than Rhino one... And Rhino or Moi do not have any free version. So this could be a great improvement for SU7 : providing a free version which keep a clear interface and user-friendly workflow, while allowing edition on complex NURBS and spline.
            Note that if anybody want to model a NURBS the way it is suggested in the first message, then it could be usefull to implement T-spline instead.
            T-spline are more powerfull than spline if you want to edit the object in the way you do with a polymodeler : extruding, pulling, stretching, adding details all the time. Just have a look here.
            For those who are searching, there was a quick job on Bezier surface plugins for sketchup : http://groups.google.com/group/Ruby-API/browse_thread/thread/0e044d3b1f7124e5
            PS : Chango70, plot-paris, I guess Soap-skin-Bubble don't use Nurbs or spline maths, there is probably just a relaxation calculus of a fixed grid of points, so it's hard maths and physics, but not the same that defines NURBS and Spline.
              Sure but Moi (the little kid of Rhino ๐Ÿ˜„ has the same easer use than Sketchup ๐Ÿ˜Ž
                plot-paris
                thanks for pointing us to t-splines, minguinhirigue.
                that sounds really good. so that is the way forward - and the way the organic SketchUp version has to go ๐Ÿ˜‰
                  chango70
                  I'd be happy to pay a limb if a Nurb or T-Spline modeler can be as intuitive as SU.
                    remus
                    Chango, sounds like MoI is the thing for you.
                    And you dont even have to give away body parts.
                    MoI, 3D modeling for designers and artists
                    MoI is a new 3D Modeling/CAD application for designers and artists. Offering a blend of precision and freeform NURBS drawing tools, it sports a unique user interface that operates seamlessly with a pen tablet.
                    (moi3d.com)
                      moi not have any free version
                      Moi has an "infinite" Demo version but you can't save anything! ๐Ÿค“
                      So cool for infinite training โ˜€
                      (use key "Print screen" can make some crazzy image anyway) ๐Ÿ˜‰
                      • I Offline
                        icetroll
                        i use various cad products and have dabbled in some of the modelling programs including 3ds Max and rhino. i totally agree that having a sketchup interface to allow nurbs modelling would make creation of complex 3d geometry much more intuitive. it is far nicer to manipulate geometry using realtime tools such as push / pull or follow me than delving into complex dialog boxes and altering parameters that are barely understandable at best. graphics products that operate more like manual drafting techniques are far more intuitive and are a more direct emphasis of the creative impulse. numbers get in the way of true creativity unless you are gifted in that faculty. it seems like sketchup could truly start a revolution in graphics if it supported nurbs modelling...just a thought
                          There is just a little problem! ๐Ÿ˜‰
                          Nurbs are not real time! Sometime you must wait the result of some calculates
                          You have not that with polygons modeler
                          Despite of that that is a terrific tools when precision is needed ๐Ÿ˜Ž
                          Moi have that and more as you can use it only with a pen graphic! ๐Ÿ˜ฎ
                          Absolute pleasure for artists! Try it! โ˜€
                          Historically the creator want to make the more ergonomic Nurbs modeler so... ๐Ÿ˜‰
                            Daniel S
                            Something very similar to plot-pairs original idea is in 3dvia shape:
                            404 Not Found
                            (forums.sketchucation.com)
                            I must say that a tool like this would be fantastic for Sketchup.
                            Daniel S
                              DIEGO-RODRIGUEZ
                              see the new tools of bonzai3d, nurbs. he can create something like this for sketchup?
                              WordPress.com โ€” 404 Error
                              (www.formz.com)
                                (www.formz.com)
                                Why have NURBS in Sketchup? Why not just use Bonzai. The two applications where designed with different intention - NURBS or Surface Mesh, fundamental difference in the of that can't be changed by the flick of a switch.
                                  ...or use some dedicated little efficient ergonomic nurbs prog like Moi ๐Ÿ˜‰
                                    chrisjk
                                    It doesn't run on a Mac!
                                    Chris
                                      Doesn't Macs have built-in utilities to run Window apps?
                                        plot-paris
                                        the last time I gave up on bonzai it crashed every three minutes... was still beta then though. ๐Ÿ˜•
                                        might give it a shot again.
                                          Yea - the beta crashed all the time (not a big surprise for a 0.x beta). But I tried a trial of 1.1 - and I had not those problems then.
                                          Just noticed that they offer this 2.0 release for free for existing 1.x customers.
                                            bonzai3d support
                                            Gentlemen,
                                            We have found and fixed quite a few issues since the early beta days of bonzai3d, and it should be a much more mature, stable program now that we have released version 2!
                                            If you would like to see some of bonzai3d's Nurbs capabilities, please take a look at these videos:
                                            http://www.formz.com/products/bonzai3d/bonzai3dVideo_640.php
                                            If you would like to give it a try, you can sign up for a Trial version from here:
                                            http://www.formz.com/products/bonzai3d/bonzai3dTrial.html
                                            If you would like to see a general feature set, you can find this here:
                                            http://www.formz.com/products/bonzai3d/bonzai3dFeatures.html
                                            Feel free to post to our forum: http://www.formz.com/forum/bonzai3d_discussion.html
                                            ...or send us a direct email if you have any questions at all regarding bonzai3d!
                                            Explore * Design * Deliver
                                            http://www.bonzai3d.com
                                            Version 2.5 Now Available!
                                            • 2 / 3
