    [Plugin] Double line
    91 Posts 38 Posters 68.0k Views 38 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Remember good ol' dline.lsp in Autocad ?
      Here is a similar plugin to draw these kind of things:
      Available options (on TAB press):
      -justification
      -caps
      -draw axis
      -draw face
      -make group
      -width and height
      -close
      Enjoy !
      EDIT 21.09.08: "close" option added, options selection persistent.
      EDIT 23.09.08: changed the shortcut for "close" option: "x" instead of "c" which is a default shortcut for "circle".
      EDIT 25.09.08: changed the shortcut for "close" option: double-click.
      EDIT 26.09.08: changed the "undo": one wall at a time.
      EDIT: 10.04.10 file_loaded? bug fixed
      EDIT: 11.04.10 file_loaded? call removed
      EDIT: TIG
      Please download the latest RB [in RBZ format from the SketchUcation PluginStore]http://sketchucation.com/pluginstore?pln=dline2 It is now recoded for compatibility with MAC & PC and suitable for v8 to >=v2015.
      TAB (up) now opens the dialog on MAC and PC.
      Its lines are forced 'flat' - constrained to the first picked point's Z.
      If it's grouped it is given a unique name ["DLINE#n"].
      DB
      • EdsonE Offline
        Edson
        fantastic gift, didier! thanks!
        http://www.mahfuz.arq.br
        • MarianM Offline
          Marian
          All hail the WISE and KIND DIDIER.
            rv1974
            I was missing this tool. Many thanks indeed!
            Some minor problems:
            1/ Sometimes it refuses to make "walls" after tracing over existing lines.
            2/ Sometimes it it makes negative Z height.
            3/ Could the last parameters input be remembered?
            Could there be option to get vertical (along world z axis) not perpendicular "wall" to sloped face?...with sloped\terraced
            upper cap to keep average height? 😮
              Didier Bur
              1/I know how to fix this. wait next release
              2/This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
              3/Yes. For now the tool only remembers prameters if you draw several walls without exiting it.
              P.S.: I guess a "close" option to come back to the very first point would be nice ?
              DB
                Matt666
                Hi Didier !
                Thank you for this another great plugin !!
                J'ai juste un petite question : Tu dois connaitre archicad ! L'outil de dessin de mur permet de modifier la justification du pan de mur que l'on va dessiner...
                I have a question for you : I suppose you know Archicad... In archicad, we have possibility of changing the justification while you are drawing the 2d wall...
                For example :
                Wall 1 = Justification "center"
                Wall 2 = Justification "Left"
                etc..
                In just one command !
                Is it possible to do that ?
                Frenglish at its best !
                My scripts
                  marcosrodrigues
                  Thank you, Didier!
                  | menos é mais
                    sepo
                    Very useful...looking forward to next update. Thanks Didier.
                    • arqpadaoA Offline
                      arqpadao
                      Hi Didier
                      thanks, this is great.
                      fernando padão
                      arquiteto
                      porto alegre - brasil
                      http://arqpadao.blogspot.com
                      • free agentF Offline
                        free agent
                        very handy, thanx!
                        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                          Didier Bur
                          Some enhancemments added today. See top of post.
                          DB
                            @ Tig Same problem but ...
                            Just enter any number then backspace for erase it then write c then Enter 😉
                            And you can keep your C shortcut 😄
                            • honoluludesktopH Offline
                              honoluludesktop
                              Are any other script.rb required to be installed in the plugin folder?
                                Matt666
                                Hi Didier !!
                                One question : Is it possible to add an "undo" key inside the command ?
                                Thank you !
                                My scripts
                                • H Offline
                                  Hazza
                                  Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
                                  That is awesome, thank you...
                                  See all of my SketchUp models here.
                                    Didier Bur
                                    I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                                    I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
                                    BTW, how to detect the Shift+enter keys pressed ?
                                    I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
                                    @honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
                                    @Pilou: want always more, hey ? i'll try to do it...
                                    DB
                                      mike d
                                      thanks
                                      The grass is always GREENER on the roof.
                                      • daikuD Offline
                                        daiku
                                        This is fantastic, Didier. I have one suggestion (for now 😄 😞 Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
                                        Clark Bremer
                                        http://www.northernlightstimberframing.com
                                          With some arcs now? 💚
                                            Didier Bur
                                            With some arcs now?
                                            No no no. Ask TIG! 🤣
                                            BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
                                            DB
                                            • 1 / 5
