Inferencing issues
Since I got my new computer a couple of weeks ago my inferencing seems to have gone crazy. I've been using SU for some years and have always found inferencing very helpful. However since changing over to my Vista 64 bit computer I'm finding that my tools are inferencing in ways they never have before. For example, I want to move a group so I zoom in, use my move tool to grab a point on the group then zoom out, find the point I want to snap too, zoom in and try to click on the new point. But I can't because somehow the group is inferenced on one of the red/green/blues axis and will only move in that direction. So I have to cancel the move and try it all over again. Does that make sense? I've never encountered this before and its a real pain. Is it a vista issue?
check if you have tict "use hardware acceleration" at windows/preferences/openGL ,strange things hapen if you havent.
Bep van Malde
Hi Bep,
Yes I've got that ticked already.
Almost sounds like you've run into a gluiing problem. Make sure the component is not glued by right clicking on it and select "unglue". It might no be that though.
Chris
Its not that either Chris as this can happen with anything I try to move. I've tried to deliberately make it happen but haven't managed it yet so I've no idea what I do that sets it off.
There are a number of known bugs with inferencing that surfaced in V6, they were fine in previous versions. Because I teach in many locations and the students are often on a variety of different computers I have found that the severity of the bug varies by the video card. Things work only slightly poorly on my computer whereas the same bug is much worse on another.
What is your video card? -
Also, are your graphic card drivers up to date?
on my laptop at home sometimes the little dot at the tip of the cursor vanishes, thus making it difficult to grab or drop things precisely at one point.
sometimes restarting SketchUp helps, sometimes it doesn't. but most of the time it vanishes after some 15 minutes ore so.is that to be placed in the same category of graphic card problems?
I would guess yes.
Kevsterman,
You could also try turning off (unticking) Fast Feedback from the Preferences>OpenGL pane.
Also, some mouse drivers (like Logitech's or the Microsoft Intellipoint software) have not worked very well with many people, and the standard Windows driver seems to be more reliable.
Just fumbling
Anssi
Its an Nvidia Geforce 9800 GX2. Is this one that severely affects the bug? All my drivers are up to date.
I'll check on this one and see if its ticked or not.
I appreciate everyones help.
Register LoginAdvertisement
