    Windowizer
    86 Posts 36 Posters 14.4k Views 36 Watching
    • BurkhardB Offline
      Burkhard
      Hi Rick, any chance to get the windowizer with default color for frames and glasses?
      Or maybe as a suggestion for V4.
      [http://www.ia-plus.de(http://www.ia-plus.de)]
        rv1974
        Hi Rick!
        Could true box (not single plane) glazing be added in v4? 🎉
        It's good for big boy renderers like vray.
          RickW
          It's in there 😄 I edited the above short-list to reflect that (pardon the pun). Hopefully, this will be justification for letting other projects slide a bit...
          RickW
          [www.smustard.com](http://www.smustard.com)
            RickW
            It's done for v4. I worked hard on it last week, and now have full 3D frames [ED: and glass], mullions for non-quadrilateral faces, faster performance, and more secret stuff. 😄
            If I get time this week, it should be available next week.
            RickW
            • P Offline
              Phil Rader AIA
              Cool Rick I'm looking forward to V4. As I have said B4 Windowizer is essential to me.
              http://www.philrader.com
                RickW
                Just a quick shot of some samples
                Sample output from Windowizer4
                Detail showing full 3D frame & glass, plus wall-cutting capability
                RickW
                • PixeroP Offline
                  Pixero
                  That looks really good. Does the glass have thickness? I.e. not just a single plane.
                  (For correct rendering with refraction it must have thickness.)
                    RickW
                    Yes, glass has thickness. It should be evident in the detail image (click on it for a larger view) - there should be 3 shades of gray for the window frame as you look near/through the glass. I used a 1" thick glass setting (which in the real world would be two 1/4"-thick panes with the outside faces 1" apart, but is shown as a 1" thick piece of glass).
                    For rendering, do you need (for example) the 1/4"-thick glass at both faces?
                    RickW
                      sepo
                      You do not have to have thickness of glass for rendering..actually most of the time it creates the problems.
                      btw windowiser looks good 👍
                        chango70
                        Hey great effort! Thanks Rick. I can't wait for v4. 😍
                        • K Offline
                          kwistenbiebel
                          As Sepo states, A single surface for glass is much better for rendering.
                          In Archviz rendering, double surface glass gets you in trouble as the refraction + caustics kills render time.
                          • ToboboT Offline
                            Tobobo
                            I can't thank you enough Rick.
                            You Ruby is in my top 5 to get.
                            Toby
                            Philippians 4:13
                              marcosrodrigues
                              Same here. A very useful script. Good news, Rick.
                              | menos é mais
                              • P Offline
                                Phil Rader AIA
                                OH please give us the option of NOT having double surface glass. I don't use a rendering application much and so I would prefer to only have a single polygon surface for the glass. I do hope that remains an option.
                                  RickW
                                  I can make glass thickness an option 😄 (naturally, it's easier coding to have a single face, but since the coding is done for double face, adding a check for glass thickness is no problem).
                                  EDIT: Easier than I thought - just specify a glass thickness of 0 😄
                                  RickW
                                    sepo
                                    Fantastic news Rick...
                                    • AnssiA Offline
                                      Anssi
                                      Wonderful news!
                                      Anssi
                                      • K Offline
                                        KustuRA
                                        ...my signature here...
                                        • jujuJ Offline
                                          juju
                                          Seems like I'd be handing over some more cash to Smustard quite soon... 😉
                                          • EdsonE Offline
                                            Edson
                                            @rickw said:
                                            I'll throw some items out there for a consensus "vote":
                                            1a. V4 will cut an opening in a "wall", and a "wall" is determined by the distance between two faces. I can hard-code a reasonable distance value (currently 16"/~40cm), or I can make it user-defined.
                                            1b. If user-defined, do you want to see it in the main dialog every time you use Windowizer, or would you prefer it to be located in a separate configuration dialog?
                                            1. V4 groups the resulting window assembly. I can add an option to group or not group this, if desired (the group would be exploded if non-grouping was selected).
                                            2. When multiple faces are selected for a Windowizer operation, should "undo" work on just the last window assembly created, or on all of them? For clarification: currently in v4, 10 faces selected to be Windowized would result in 10 separate actions, thus 10 separate "undo" actions. This could be an option as well, subjecting it to question 1b. (main dialog or separate configuration dialog?)
                                            1a. user defined
                                            1b. separate window
                                            2. group it by default
                                            3. undo should work on all of them. option on main dialog.
                                            http://www.mahfuz.arq.br
                                            • 1 / 5
