πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Windowizer
86 Posts 36 Posters 8.3k Views 36 Watching
    Burkhard
    Hi Rick, any chance to get the windowizer with default color for frames and glasses?
    Or maybe as a suggestion for V4.
    [http://www.ia-plus.de(http://www.ia-plus.de)]
      rv1974
      Hi Rick!
      Could true box (not single plane) glazing be added in v4? πŸŽ‰
      It's good for big boy renderers like vray.
        RickW
        It's in there πŸ˜„ I edited the above short-list to reflect that (pardon the pun). Hopefully, this will be justification for letting other projects slide a bit...
        RickW
        [www.smustard.com](http://www.smustard.com)
          RickW
          It's done for v4. I worked hard on it last week, and now have full 3D frames [ED: and glass], mullions for non-quadrilateral faces, faster performance, and more secret stuff. πŸ˜„
          If I get time this week, it should be available next week.
          RickW
            Phil Rader AIA
            Cool Rick I'm looking forward to V4. As I have said B4 Windowizer is essential to me.
            http://www.philrader.com
              RickW
              Just a quick shot of some samples
              Sample output from Windowizer4
              Detail showing full 3D frame & glass, plus wall-cutting capability
              RickW
                Pixero
                That looks really good. Does the glass have thickness? I.e. not just a single plane.
                (For correct rendering with refraction it must have thickness.)
                  RickW
                  Yes, glass has thickness. It should be evident in the detail image (click on it for a larger view) - there should be 3 shades of gray for the window frame as you look near/through the glass. I used a 1" thick glass setting (which in the real world would be two 1/4"-thick panes with the outside faces 1" apart, but is shown as a 1" thick piece of glass).
                  For rendering, do you need (for example) the 1/4"-thick glass at both faces?
                  RickW
                    sepo
                    You do not have to have thickness of glass for rendering..actually most of the time it creates the problems.
                    btw windowiser looks good πŸ‘
                      chango70
                      Hey great effort! Thanks Rick. I can't wait for v4. 😍
                        kwistenbiebel
                        As Sepo states, A single surface for glass is much better for rendering.
                        In Archviz rendering, double surface glass gets you in trouble as the refraction + caustics kills render time.
                          Tobobo
                          I can't thank you enough Rick.
                          You Ruby is in my top 5 to get.
                          Toby
                          Philippians 4:13
                            marcosrodrigues
                            Same here. A very useful script. Good news, Rick.
                            | menos Γ© mais
                              Phil Rader AIA
                              OH please give us the option of NOT having double surface glass. I don't use a rendering application much and so I would prefer to only have a single polygon surface for the glass. I do hope that remains an option.
                                RickW
                                I can make glass thickness an option πŸ˜„ (naturally, it's easier coding to have a single face, but since the coding is done for double face, adding a check for glass thickness is no problem).
                                EDIT: Easier than I thought - just specify a glass thickness of 0 πŸ˜„
                                RickW
                                  sepo
                                  Fantastic news Rick...
                                  • AnssiA Offline
                                    Anssi
                                    Wonderful news!
                                    Anssi
                                      KustuRA
                                      ...my signature here...
                                      • jujuJ Offline
                                        juju
                                        Seems like I'd be handing over some more cash to Smustard quite soon... πŸ˜‰
                                        • EdsonE Offline
                                          Edson
                                          @rickw said:
                                          I'll throw some items out there for a consensus "vote":
                                          1a. V4 will cut an opening in a "wall", and a "wall" is determined by the distance between two faces. I can hard-code a reasonable distance value (currently 16"/~40cm), or I can make it user-defined.
                                          1b. If user-defined, do you want to see it in the main dialog every time you use Windowizer, or would you prefer it to be located in a separate configuration dialog?
                                          1. V4 groups the resulting window assembly. I can add an option to group or not group this, if desired (the group would be exploded if non-grouping was selected).
                                          2. When multiple faces are selected for a Windowizer operation, should "undo" work on just the last window assembly created, or on all of them? For clarification: currently in v4, 10 faces selected to be Windowized would result in 10 separate actions, thus 10 separate "undo" actions. This could be an option as well, subjecting it to question 1b. (main dialog or separate configuration dialog?)
                                          1a. user defined
                                          1b. separate window
                                          2. group it by default
                                          3. undo should work on all of them. option on main dialog.
                                          http://www.mahfuz.arq.br
                                          • 1 / 5
                                          1 / 5
