    Windowizer
    86 Posts 36 Posters 16.6k Views 36 Watching
      RickW
      Just a quick shot of some samples
      Sample output from Windowizer4
      Detail showing full 3D frame & glass, plus wall-cutting capability
      RickW
      www.smustard.com
      • PixeroP
        Pixero
        That looks really good. Does the glass have thickness? I.e. not just a single plane.
        (For correct rendering with refraction it must have thickness.)
          RickW
          Yes, glass has thickness. It should be evident in the detail image (click on it for a larger view) - there should be 3 shades of gray for the window frame as you look near/through the glass. I used a 1" thick glass setting (which in the real world would be two 1/4"-thick panes with the outside faces 1" apart, but is shown as a 1" thick piece of glass).
          For rendering, do you need (for example) the 1/4"-thick glass at both faces?
          RickW
          www.smustard.com
            sepo
            You do not have to have thickness of glass for rendering..actually most of the time it creates the problems.
            btw windowiser looks good 👍
            • C
              chango70
              Hey great effort! Thanks Rick. I can't wait for v4. 😍
              • K
                kwistenbiebel
                As Sepo states, A single surface for glass is much better for rendering.
                In Archviz rendering, double surface glass gets you in trouble as the refraction + caustics kills render time.
                • ToboboT
                  Tobobo
                  I can't thank you enough Rick.
                  You Ruby is in my top 5 to get.
                  Toby
                  Philippians 4:13
                    marcosrodrigues
                    Same here. A very useful script. Good news, Rick.
                    | menos é mais
                    • P
                      Phil Rader AIA
                      OH please give us the option of NOT having double surface glass. I don't use a rendering application much and so I would prefer to only have a single polygon surface for the glass. I do hope that remains an option.
                      http://www.philrader.com
                        RickW
                        I can make glass thickness an option 😄 (naturally, it's easier coding to have a single face, but since the coding is done for double face, adding a check for glass thickness is no problem).
                        EDIT: Easier than I thought - just specify a glass thickness of 0 😄
                        RickW
                        www.smustard.com
                          sepo
                          Fantastic news Rick...
                          • AnssiA
                            Anssi
                            Wonderful news!
                            Anssi
                            • K
                              KustuRA
                              ...my signature here...
                              • jujuJ
                                juju
                                Seems like I'd be handing over some more cash to Smustard quite soon... 😉
                                • EdsonE
                                  Edson
                                  @rickw said:
                                  I'll throw some items out there for a consensus "vote":
                                  1a. V4 will cut an opening in a "wall", and a "wall" is determined by the distance between two faces. I can hard-code a reasonable distance value (currently 16"/~40cm), or I can make it user-defined.
                                  1b. If user-defined, do you want to see it in the main dialog every time you use Windowizer, or would you prefer it to be located in a separate configuration dialog?
                                  1. V4 groups the resulting window assembly. I can add an option to group or not group this, if desired (the group would be exploded if non-grouping was selected).
                                  2. When multiple faces are selected for a Windowizer operation, should "undo" work on just the last window assembly created, or on all of them? For clarification: currently in v4, 10 faces selected to be Windowized would result in 10 separate actions, thus 10 separate "undo" actions. This could be an option as well, subjecting it to question 1b. (main dialog or separate configuration dialog?)
                                  1a. user defined
                                  1b. separate window
                                  2. group it by default
                                  3. undo should work on all of them. option on main dialog.
                                  http://www.mahfuz.arq.br
                                  • jujuJ
                                    juju
                                    1a) User defined, but with the option to set parameters within which script should search for the other face of the wall.
                                    1b) Main dialogue box.
                                    2) Add option to have the output either grouped or ungrouped.
                                    3) Last window created. I think one should check the window before going on to create the next.
                                      RickW
                                      Okay, here's a simple form for answering the questions (which will help me tabulate responses).
                                      (Edson & Juju, thanks for your feedback - I've logged your responses already)
                                      RickW
                                      www.smustard.com
                                      • AnssiA
                                        Anssi
                                        1a. [EDITED] V4 will cut an opening in a "wall", and a "wall" is determined by the maximum distance between two faces. I can hard-code a reasonable distance value (currently 16"/~40cm maximum), or I can make it user-defined.
                                        1a User-defined
                                        1b Main dialog is OK - at least in the version I have it is still uncluttered enough
                                        2 Grouping is OK, adding the option is OK too, but not absolutely necessary
                                        3 Undo all in one go is IMO the way to go
                                        Cheers
                                        Anssi
                                          RickW
                                          EDIT: If you answer using this survey form, I can better track the responses.
                                          RickW
                                          www.smustard.com
                                            RickW
                                            Okay, based on responses so far, I've made some determinations:
                                            1. This will be user-configurable in a separate dialog, as I expect it won't change very often - if you never have a wall thicker than 16"/40cm, it will never change! 😄
                                            2. I will add the grouping option to the main dialog
                                            3. "Undo" will undo all windows created in that instance.
                                            Thanks for the input,
                                            RickW
                                            www.smustard.com
                                            • 1 / 5
