    Least used function of SU
    36 Posts 20 Posters 3.1k Views 20 Watching
      david.
      I also wonder why "Flip Along" would get least used, since I use it quite a lot for mirroring. It doesn't get much easier if that's what you're trying to do. That's my favorite way to create objects that have symmetry (ie, draw half, then select, move/copy, flip).
      As for my least used, there are many that I don't use much. But, of the standard tools, I don't use Freehand that much.
      • david_hD Offline
        david_h
        Maybe this post should get moved to the Ruby Forum. I have brought this up before but It didn't get much play, but my all time favorite wish for just the improvement of my Sketchup workflow would be to be able to use the outliner to be able to view a nested compoenent and its parent but still have the rest of the model hidden. I know thru outliner you can do something like it but it seems laborious as Plot expalined at one time and it really doesnt get me where I wanna be. To able to Move up or down the heirarchical tree and edit as I please but only showing the next parent up or 2 generations or 3 depending on how I toggle it. And it should be some kind of easy toggle. Am I comin' thru here? is there something I just don't know how to do taht all you guys can do? Tell me. . .I want to know. . .
        Tell me. . .. I want to know!!!!
        • DanielD Offline
          Daniel
          Imperial and metric units are not so much functions as they are settings, so I wouldn't include them. For me, the least (as in never) used functions would be:
          polygon
          fog (although I can see where it might be useful)
          walkthrough
          outliner
          My avatar is an anachronism.
          • P Offline
            PKast
            Until I heard it mentioned above I didn't know what my least used tool was. The mention of "freehand" set my light bulbs off. I don't think I have ever used it except once to play around with. After that fog, and outliner, but I do like fog and I do not wish it to go away.
            • Chris FullmerC Offline
              Freehand is useful from time to time, but did you know that it has an shift-modifier to it? Check it out. Hold shift while drawing and you get a freehand line that is free of inferencing. Its a 3dpolyline. That is a tool I never use.
              Chris
              All my Plugins I've written
                Duh... 😲
                  remus
                  It locks the line on to a plane, though, which is a bit annoying.
                  • Z Offline
                    Zilonx
                    Every mentioned feature have their specific use. Fog can belong to the least used functions for some people, but it is very useful for a lot of people. Styles are simply a must - and an amazing feature. Layout is getting better, and is soo cool.
                    I never used the "print" icon from Sketchup!
                    • soloS Offline
                      solo
                      Autosave, is slows your modeling down, get into a habit of saving before any major operation.
                      Layout, too many great apps out there that do a better job for Google to be wasting resources on this.
                      http://www.solos-art.com
                        BTM
                        I use metric (inches confuse me), and actually use flip along axis quite often, as well as fog and styles (I think half of my models have their own styles...). Oh, and use sun for shading. More realistic, no slower.
                        My least used functions would be;
                        tape measurer
                        protractor
                        the zoom tools
                        eraser (I probably should...)
                        and section cuts.
                          I'm surprised how often the tape measure and guidelines end up on these lists. I suppose it depends on what you do. I find these tools essential when I model.
                          Don't you ever wonder about a certain measurement in your models?
                          • Z Offline
                            Zilonx
                            Hi Solo, I think autosave is a must have feature - the slows down happens probably because other performance problems, but it can be easily disabled. About performance, I can only think about the core modeler itself - cannot run in 64 bits and cannot use 10% of the actual GPUs abilities.
                            I just cannot think about any other app that do what Layout does - can you explain?
                            Regards.
                            • jeff hammondJ Offline
                              jeff hammond
                              i use autosave but this thread just helped me get a new system i'm going to try out..
                              i always wished autosave could be set to make sequential files (i.e. autosave_house01, autosave_house02, etc.).. sometimes i like to go further back into a model than what autosave and the current file will provide me with..
                              a normal save doesn't give me what i want because then you can't go back. 'save as' is what i want but i never really used it because i have to manually type in the sequential numbers..
                              'save a copy as' however will automatically add the sequential number (ie - house copy, house copy 2, house copy 3).. i just added a shortcut for that command (⇧S) and after a quick test run, it's looking real good..
                              so yeah, maybe autosave will become a least used function for me πŸ˜„
                              dotdotdot
                                Sounds like a candidate for a new plugin...
                                  jeff hammond
                                  thing is, (and i've never really tested or confirmed this) is that i'll sometimes get a hang or occasionally a crash when using certain rubies and i'm starting to think it might have something to do with autosave..
                                  joint push pull for instance usually runs great but on rare occasions, it will hang.. i'm wondering if it has something to do with the saving of the file while the ruby is running ??
                                  dotdotdot
                                  • Z Offline
                                    Zilonx
                                    Oh, that's so true! Every model done (finished or not..) and the model folder is full with every step imaginable of the entire "development history" - for now, a manual process. This autosave configuration is a must have, but I think that it must be integrated with Sketchup.
                                    And yes, I too think that crashes are related to certain operations when saving, like plugins.
                                    • 2 / 2
