    [Plugin] GreyscaleMode
    133 Posts 56 Posters 154.4k Views 56 Watching
      I hadn't thought of it that way but I suppose since we're asking for the moon...
      I was really thinking more of "filters" for controlling values of gray to preventtwo adjacent colors from looking like the same value of gray. I'm sure you've seen the example from the old photography texts of the red, green and yellow apples shot through different colored filters on black and white film. I tried to find that photo in a quick Google search but came up empty.
        Jim
        I'm sure it can be be done, although I don't know the math involved in filtering/masking colors. To combine the ideas, a set of filter settings could be saved as a preset - named Sepia, or Black & White, as examples.
        off to day job... later.
          Matt666
          or Black & White,
          Hey !! That is exactly what I wanted to ask !! πŸ˜„ β˜€
          The same render that "Hidden lines" tool of the "Face Style" Toolbar... But we can color some entities !!!
          Great 😍 😍
          Thank you Jim !
          Frenglish at its best !
          My scripts
          • utilerU Offline
            utiler
            wow, this is becoming bigger than i thought....
            Just Curious...
              DonVid
              Greetings Jim:
              This plugin is a great addition. We can now insert
              a pdf from Lay Out and import it into cad programs
              like Vector and make a BW presentation on the actual
              Construction Documents.
              Thanks,
              DonVid
              Constr. Docs.1.pdf
              • utilerU Offline
                utiler
                too right Jim, and nice work.
                this little script portrays a nice soft presentation to both schematic and final design....
                Just Curious...
                  Jim
                  I made 2 small updates:
                  1. Right-clicking Groups and Components gives you the Revert Color option.
                  2. Implemented the suggested grey color calculation of: color = 0.3 * red + 0.59 * blue + 0.11 * green
                  Download it from the first post of this thread.
                    Hi Jim,
                    Thanks for the update. I see when opening the script that you have added the math. I don't see the Revert color option when clicking on a component, though. Is it just me?
                      Jim
                      @dave r said:
                      Hi Jim,
                      I get the Revert on Components. I honestly didn't try it until just now... but it does work. Now, if each individual Face in the Component is colored (as opposed to having the default color), you need to open the Component and right-click a face.
                        Oh, I see. I almost never paint components. I always apply the material to the faces so I didn't understand at first. Now I do.
                        Thank you.
                        Dave
                          sketchupjockey
                          very cool, thanks
                          • utilerU Offline
                            utiler
                            thanks for the update Jim, too cool....
                            Just Curious...
                            • ton baetenT Offline
                              ton baeten
                              Jim,
                              This is really a great plugin.
                              I have already used it for some presentationdrawings and it works fine.
                              Today I was playing with it again to define a nice match between specific colors and their grey-scale-representation and now, for the first time, I tried to go back and forth between grey-mode and color-mode and..........
                              it isn't possible (my mac or my partial blindness maybe ?).
                              The color mode in the pop-up menu is greyed out (so not functional) and I cann't find any 'revert color' option anywhere under my right mouse button. Neighter when selecting a group nor when going into the group and selecting seperate faces nor within the color-picker. 'Undo' doesn't do the trick either.
                              Nowbody mentionned this 'problem' before, so I guess I must be overlooking something.
                              Please help me look in the right direction to find my way back into color.
                              By the way, I really like the fact that your plugin doesn't effect the standard face colors (back and front) so you can high-light special details in one or two vivid colors. Whatever additions you ever make to this pugin, please keep that possibility in.
                              greetings,
                              Ton
                              • plot-parisP Offline
                                plot-paris
                                ...my way back into color.
                                a great title for a book, Ton πŸ˜„
                                hope you (and Jim) will be able to solve the problem.
                                  Jim
                                  Ton, thanks for the feedback.
                                  Can you open the Ruby Console and reproduce the issue? I would like to see if any errors are being shown in the Ruby Console.
                                    ton baeten
                                    Jim,
                                    Just a short message for now.
                                    Thank's, you pointed me in the right direction, the problem is solved.
                                    I have another larger SU project to finish first and had to solve another domestic 'grey-scale' problem at the same time.
                                    Will come back asap to fill you in with more details.
                                    greetings,
                                    Ton
                                      linea
                                      Thanks Jim
                                      As I reading this thread, I couldn't really see that I'd use this script but I now think it could be very useful!
                                      Jon
                                      • utilerU Offline
                                        utiler
                                        You should do that Jon, it opens up a world of possibilities ......
                                        Just Curious...
                                        • P Offline
                                          Phil Rader AIA
                                          This script is absolute genius. For working drawings which you want to print out in black and white I used to have to export color jpg images and then manually convert them to grey scale in photoshop. Now it's all internal to SU. Badda Boom Badda Bing. I love it.
                                          http://www.philrader.com
                                          • utilerU Offline
                                            utiler
                                            Not wrong Phil, i'ts great for exactly that... some of the work I do involves planning applications and what better way to communicate surrounding environment with proposed that to greyscale existing and color proposed!!!
                                            πŸ‘ to Jim....
                                            Just Curious...
                                            • 6
                                            • 7
                                            • 3 / 7
