    [Plugin] GreyscaleMode
    133 Posts 56 Posters 172.7k Views 56 Watching
      Here's another example of using the Grayscale Plugin. This is raw SU output.
      http://img.photobucket.com/albums/v506/weekender410/RBT.jpg
      • utilerU
        utiler
        Awesome Dave!!!
        Just Curious...
          Thank you Andrew. There's not much color in this model anyway but I like the effect with the grey scale option. I like that the wood grain still shows this way, too.
          • plot-parisP
            plot-paris
            @dave r said:
            ...but suppose one could choose some sort of filter factor. Suppose that you want to simulate a 25 Red filter. You might choose Red from a list of filters which would give green colors lower values (make them darker) while reds would tend to be higher values.
            do I understand it correctly that with this method you could even create a sepia effect (with some colours standing out of course πŸ˜‰ ). that would be such a cool thing!
              I hadn't thought of it that way but I suppose since we're asking for the moon...
              I was really thinking more of "filters" for controlling values of gray to preventtwo adjacent colors from looking like the same value of gray. I'm sure you've seen the example from the old photography texts of the red, green and yellow apples shot through different colored filters on black and white film. I tried to find that photo in a quick Google search but came up empty.
                Jim
                I'm sure it can be be done, although I don't know the math involved in filtering/masking colors. To combine the ideas, a set of filter settings could be saved as a preset - named Sepia, or Black & White, as examples.
                off to day job... later.
                  Matt666
                  or Black & White,
                  Hey !! That is exactly what I wanted to ask !! πŸ˜„ β˜€
                  The same render that "Hidden lines" tool of the "Face Style" Toolbar... But we can color some entities !!!
                  Great 😍 😍
                  Thank you Jim !
                  Frenglish at its best !
                  My scripts
                  • utilerU
                    utiler
                    wow, this is becoming bigger than i thought....
                    Just Curious...
                      DonVid
                      Greetings Jim:
                      This plugin is a great addition. We can now insert
                      a pdf from Lay Out and import it into cad programs
                      like Vector and make a BW presentation on the actual
                      Construction Documents.
                      Thanks,
                      DonVid
                      Constr. Docs.1.pdf
                      • utilerU
                        utiler
                        too right Jim, and nice work.
                        this little script portrays a nice soft presentation to both schematic and final design....
                        Just Curious...
                          Jim
                          I made 2 small updates:
                          1. Right-clicking Groups and Components gives you the Revert Color option.
                          2. Implemented the suggested grey color calculation of: color = 0.3 * red + 0.59 * blue + 0.11 * green
                          Download it from the first post of this thread.
                            Hi Jim,
                            Thanks for the update. I see when opening the script that you have added the math. I don't see the Revert color option when clicking on a component, though. Is it just me?
                              Jim
                              @dave r said:
                              Hi Jim,
                              I get the Revert on Components. I honestly didn't try it until just now... but it does work. Now, if each individual Face in the Component is colored (as opposed to having the default color), you need to open the Component and right-click a face.
                                Oh, I see. I almost never paint components. I always apply the material to the faces so I didn't understand at first. Now I do.
                                Thank you.
                                Dave
                                  sketchupjockey
                                  very cool, thanks
                                  • utilerU
                                    utiler
                                    thanks for the update Jim, too cool....
                                    Just Curious...
                                    • ton baetenT
                                      ton baeten
                                      Jim,
                                      This is really a great plugin.
                                      I have already used it for some presentationdrawings and it works fine.
                                      Today I was playing with it again to define a nice match between specific colors and their grey-scale-representation and now, for the first time, I tried to go back and forth between grey-mode and color-mode and..........
                                      it isn't possible (my mac or my partial blindness maybe ?).
                                      The color mode in the pop-up menu is greyed out (so not functional) and I cann't find any 'revert color' option anywhere under my right mouse button. Neighter when selecting a group nor when going into the group and selecting seperate faces nor within the color-picker. 'Undo' doesn't do the trick either.
                                      Nowbody mentionned this 'problem' before, so I guess I must be overlooking something.
                                      Please help me look in the right direction to find my way back into color.
                                      By the way, I really like the fact that your plugin doesn't effect the standard face colors (back and front) so you can high-light special details in one or two vivid colors. Whatever additions you ever make to this pugin, please keep that possibility in.
                                      greetings,
                                      Ton
                                      • plot-parisP
                                        plot-paris
                                        ...my way back into color.
                                        a great title for a book, Ton πŸ˜„
                                        hope you (and Jim) will be able to solve the problem.
                                          Jim
                                          Ton, thanks for the feedback.
                                          Can you open the Ruby Console and reproduce the issue? I would like to see if any errors are being shown in the Ruby Console.
                                          • ton baetenT
                                            ton baeten
                                            Jim,
                                            Just a short message for now.
                                            Thank's, you pointed me in the right direction, the problem is solved.
                                            I have another larger SU project to finish first and had to solve another domestic 'grey-scale' problem at the same time.
                                            Will come back asap to fill you in with more details.
                                            greetings,
                                            Ton
                                            • 3 / 7
