    [Plugin] Lines to tubes
    131 Posts 61 Posters 297.0k Views 61 Watching
      Might it be the scripts are getting corrupted?
      How are you downloading / installing them ?
      DO you have other scripts that work OK ?
        Steuart
        Hi Tig,
        I simply put them into the plugins folder - the same as i have put several other plugins (see list below - I have removed the lines2tubes and the other similar plugin that was crashing the program) with no problems (hard disk/library/application support/google sketchup 8/sketchup/plugins
        centerpoint.rb
        DEFPARAM_Dir
        Examples [folder]
        examples.rb
        Fredo6Trace.txt
        LIBFREDO6_Dir_43
        LibFredo6.rb
        LibTraductor.rb
        maxwell[folder]
        maxwell.rb
        Ocean[folder]
        ocean_extension.rb
        ROUNDCORNER_Dir_23
        Smooze[folder]
        Soften.rb
        Utilities[folder]
        utilities.rb
        ZLoader__RoundCorner.rb
          πŸ˜•
            bharvey
            πŸ˜„ You're freaking awesome Didier!
            Guard/Handrails just got alot easier.
            Thanks!!!
            • N Offline
              ninehundred
              also, here is a picture of the one ive made in blender but as mentioned before you cant edit the joins or create a join.
              http://archibitd.tumblr.com/image/40256783011
                I've given some pointers in your other very similar thread...
                • slocraftusS Offline
                  slocraftus
                  how can i download this plugin?
                  • gillesG Offline
                    gilles
                    First page, don't you read the post?
                      slocraftus
                      will it be useful to create the rope on knife?
                      or can you tell me the better plugin,if it exists
                      • gillesG Offline
                        gilles
                        Any reference image?
                          Some plugins about that are there!
                          • ssokolS Offline
                            ssokol
                            Hi , I have problem, Line2Tubes doesn't show up under tools in Sketchup 2014?
                            In Sketchup 8 works perfect.
                            Any help?
                              sarkarshomit
                              Any help?
                              +1 to that...have similar problem...wont show up in SU2014...installed it using Sketchucation Plugin store app...installs through that in plugins folder of SU2014...but wont show up anywhere....please help...very useful...kinda missing it...dont want to go back to SU8...
                              PS: I Read the whole thread and checked that I dont have any older versions installed.
                              Till then using TIG's pipe along path
                                Didier needs to rework his rb file for v2014 compatibility and republish it...
                                BUT you can do it temporarily for your own use, even though his script is 'packed'.
                                Open the file lines2tubes.rb in Notepad, and go to the end:
                                Change
                                ...}.unpack("m")**.to_s**
                                to read
                                ...}.unpack("m")**[0]**
                                Save the changes.
                                Restart SketchUp.
                                The script will then load and work in v2014 !
                                This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
                                These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
                                • demD Offline
                                  dem
                                  Unfortunately, while plugin starts in v2014, it still does not work. Hope Didier wil fix it
                                  upd. oops, im sorry. its was a conflict with old CompoSpray version
                                    Did you do the temporary edit fix I suggested two posts ago ?
                                    • unclebimU Offline
                                      unclebim
                                      Change
                                      to read
                                      Save the changes.
                                      Restart SketchUp.
                                      Thank you! Fixed!
                                        ckho1985
                                        Change
                                        to read
                                        Save the changes.
                                        Restart SketchUp.
                                        Working in Mac… not sure what to do 😞
                                          Working? Or not working?
                                            ckho1985
                                            as in I know I could drag n drop the .rb file in windows.
                                            but now I am using a mac in office computer. can't do the drag-n-drop anymore. (or is there a way?)
                                            anyway i can alter the .rbZ file to work?
                                            another suggestion. would be superb if there is a option of having square / rectangular tube rather than circular cylinder only. πŸ‘ πŸ‘ πŸ‘
                                            • 6
                                            • 7
                                            • 4 / 7
