    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      alvin_pox
      @tig said:
      Sounds like the file is corrupted as there is no reference to 'book' in it. πŸ˜•
      Get the file again and put the .rb file into the Plugins folder, and retry.
      Don't edit it with a word-processor or similar as this might corrupt it...
      The file is 'packed' and is unencrypted as it loads - I have no problems with it so you seem to have messed up something in the file's text itself ? πŸ˜•
      Have downloaded the file again and it works now!
      I noticed that the file I had yesterday had a big red "Rb" on the file icon thumbnail, but it doesn't today after I redownloaded it.
      I also tried other plugins yesterday and all seemed to get the same error message when loading and the big red Rb on their thumbnails, so it doesn't look like it was a single corrupted file. Weird.
      But it's all sorted now. Thanks so much:p
        And Wings3D can reload 3DS format from 3Dwharehouse or from SU πŸ˜‰
        • majidM Offline
          majid
          yeap, it has wide range of import/export formats included. very handy,... sort of free subd/smooth πŸ˜‰
            btxscg
            it's great
            • irwanwrI Offline
              irwanwr
              i'd like to thank the author, Didier for this very useful plugin.
              i used to utilise the push/pull tool before. with this plugin, i could just do it on the line frames and one or two more clicks.
              thank you very much πŸ‘
                Steuart
                Hi Didier and all.
                I have just installed the Lines2tubes plug in. Initially I tried to use it and it crashed (of course before I had saved anything - auto save does not seem to work unless you have done at least an initial save). Then each time I tried to re:launch SU it would instantly crash. I also tried TubeAlongPath and pretty much the same thing happens. In each case it was fine once I had remeoved the plug in. Anyone any ideas? I am using a Macbook pro, with 10.5 and SU 8. I would love to be able to use the program as it would save a huge amount of time.
                  Might it be the scripts are getting corrupted?
                  How are you downloading / installing them ?
                  DO you have other scripts that work OK ?
                    Steuart
                    Hi Tig,
                    I simply put them into the plugins folder - the same as i have put several other plugins (see list below - I have removed the lines2tubes and the other similar plugin that was crashing the program) with no problems (hard disk/library/application support/google sketchup 8/sketchup/plugins
                    centerpoint.rb
                    DEFPARAM_Dir
                    Examples [folder]
                    examples.rb
                    Fredo6Trace.txt
                    LIBFREDO6_Dir_43
                    LibFredo6.rb
                    LibTraductor.rb
                    maxwell[folder]
                    maxwell.rb
                    Ocean[folder]
                    ocean_extension.rb
                    ROUNDCORNER_Dir_23
                    Smooze[folder]
                    Soften.rb
                    Utilities[folder]
                    utilities.rb
                    ZLoader__RoundCorner.rb
                      πŸ˜•
                        bharvey
                        πŸ˜„ You're freaking awesome Didier!
                        Guard/Handrails just got alot easier.
                        Thanks!!!
                        • N Offline
                          ninehundred
                          also, here is a picture of the one ive made in blender but as mentioned before you cant edit the joins or create a join.
                          http://archibitd.tumblr.com/image/40256783011
                            I've given some pointers in your other very similar thread...
                            • slocraftusS Offline
                              slocraftus
                              how can i download this plugin?
                              • gillesG Offline
                                gilles
                                First page, don't you read the post?
                                  slocraftus
                                  will it be useful to create the rope on knife?
                                  or can you tell me the better plugin,if it exists
                                  • gillesG Offline
                                    gilles
                                    Any reference image?
                                      Some plugins about that are there!
                                      • ssokolS Offline
                                        ssokol
                                        Hi , I have problem, Line2Tubes doesn't show up under tools in Sketchup 2014?
                                        In Sketchup 8 works perfect.
                                        Any help?
                                          sarkarshomit
                                          Any help?
                                          +1 to that...have similar problem...wont show up in SU2014...installed it using Sketchucation Plugin store app...installs through that in plugins folder of SU2014...but wont show up anywhere....please help...very useful...kinda missing it...dont want to go back to SU8...
                                          PS: I Read the whole thread and checked that I dont have any older versions installed.
                                          Till then using TIG's pipe along path
                                            Didier needs to rework his rb file for v2014 compatibility and republish it...
                                            BUT you can do it temporarily for your own use, even though his script is 'packed'.
                                            Open the file lines2tubes.rb in Notepad, and go to the end:
                                            Change
                                            ...}.unpack("m")**.to_s**
                                            to read
                                            ...}.unpack("m")**[0]**
                                            Save the changes.
                                            Restart SketchUp.
                                            The script will then load and work in v2014 !
                                            This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
                                            These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
                                            • 4 / 7
