    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 99.5k Views 44 Watching
    • Didier BurD Offline
      Didier Bur
      the GE Snapshot (which is a horizontal face on 0 z axis) would stop the trees falling under i
      Yes. The ruby "raycast" method don't care of hidden layers or entities (no way to get rid of this). You should make a component of your GE snapshot, save it outside your model, delete it in the model, spray your trees, and bring the GE snapshot component back afterwards.
      Regards,
      DB
        If you unlock it and cut it,you can insert it into another model with the Edit > Paste in place command. At the end you can bring it back in the same way to make it sure it is really at the same place.
        • Chris FullmerC Offline
          Any thoughts on my requests Didier? Look back a few posts. Especially the first one. It's really important to my workflow. Would it be possible to include? Thanks for looking,
            Didier Bur
            Yes, it is possible to include your requests, but you'll have to be patient ๐ŸŽ‰
            I'm on a huge project now and I'm afraid I must leave my freebies as they are for a couple of weeks...
            DB
              Oh I can be patient ๐Ÿ˜„ I just wanted to make sure you saw my thoughts and would see if they were good ideas or useless. Thanks for looking at it Didier, you're the best!
                sbthomas
                Gaieus & Didier;
                Using your suggestions I have been able to overcome the issue of spraying in the valleys of GE snapshots. The process is as follows:
                Get GE snapshot
                toggle terrain
                save-as "snapshotname"
                unlock terrain
                explode terrain
                edit>copy terrain
                file>new sketchup project
                edit>paste-in-place
                insert component
                spray component
                delete terrain
                import saved snapshot
                place model back to GE
                thanks again for your help.
                STAN
                  Hi Stan,
                  In order to make sure your original terrain remains intact,after the step where you copy it,you can just undo the steps in the original model (the copied version will remain on the clipboard and you can use the paste in place command in the new model to spray the components).
                    This is one of my absolute favourite rubies. I just detailed a large terrain model with 4000 trees in no time. I would never have gotten such a rich detail to it manually.
                      Hi Didier, I have found that this script is conflicting with progressbar.rb, and therefore crashing all scripts that are using progressbar (makefaces in particular!, but I found the problem while developing my own script). There is a pb.update() method in the progressbar that seems to not work so I'm guessing that is where the conflict is - but I could be WAAAAY off. Thanks Didier!
                      I was wondering if anyone else could confirm this?
                        Does it make use of the disable UI argument for .start_operation ?
                          Didier Bur
                          No.
                          Is there still a conflict with progressbar ? ๐Ÿ‘Š
                          I changed the class and methods names to get rid of any conflict in the latest version released. ๐Ÿ˜ฒ
                          DB
                            It'd be interesting to see what speed this plugin worked at with the SU UI disabled. Any chance of an updated version?
                              Nope! It is working great now with progressbar. Thanks for fixing it so quickly too,
                                milfot
                                Wow, this plugin is fantastic!!
                                Much appreciated... i am off to build a forest.
                                ..cam
                                  denna003
                                  THAnk you very much!!!! ๐Ÿ˜‰
                                    AcesHigh
                                    Didier, is this the last version of your tool?
                                    Can I make a suggestion? It seems the altitude option is too "hard". I mean, I think you could add some dialogue to add a % of chance that components will spray below and above the maximum altitude. That way, they will concentrate on the set altitude, but some of them will spread casually beyond (unless you set the chance of that happening to 0%)
                                      tomislavm
                                      Thank You!
                                      Where in Croatia?
                                        madhav
                                        Thanks a lot
                                          Didier Bur
                                          Where in Croatia?
                                          Pisak, that's 40kms South of Split and 20kms North of Makarska.
                                          DB
                                            tomislavm
                                            Nice place for vacation!
                                            • 2 / 5
