    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 103.6k Views 44 Watching
    • Didier BurD
      Didier Bur
      %(#FF0000)[COMPO SPRAY 1.3 is now obsolete.
      DOWNLOAD version 1.4 (Jan, 2nd 2011) here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=76]
      New thread on SketchUcation here: http://forums.sketchucation.com/viewtopic.php?f=323&t=33908
      Hi all,
      Here is an update of the component spray tool (updated PDF doc included).
      What's new in 1.3.:
      New "shape" option to drop component at each vertex of selected faces.
      Bug fix when loading the script on Mac.
      Bux fix that froze the script when no destination layer were specified.
      Enjoy !
      EDIT:
      Last version posted 03.09.10 (no more progressbar conflict, not an rbs)
      DB
      • CadFatherC
        CadFather
        thanks!
        • I
          ilay7k
          Thank you 👍
          Have good time at holidays!
          • R
            remus
            What a treat, cheers didier.
            • FrederikF
              Frederik
              Thanks, Didier..!! 😄
              This is just so GREAT..!!
              Cheers
              Kim Frederik
              • J
                Jon
                Thanks a LOT!
                Jon
                KT Team member
                • D
                  dylan
                  Thanks Didier......enjoy the holiday
                  http://dmdarchitecture.co.uk/
                  • C
                    chango70
                    • W
                      wq418
                      Thanks a lot!
                      you are great!
                      • plot-parisP
                        plot-paris
                        what a great enhancement, Didier!
                        the vertex spray function is very neat. would have come in handy for a project I had to finish on frieday 😄
                        this fantastic new feature gives me the idea of a "selected face spray tool" - basically a combination of this new vertex-spray option and the spray-pressure variable. you select the faces of the terrain, where you want trees and choose the density (like 70%). now the plugin sprays only on the selected faces of the terrain, but regardless of the vertex distribution (because the density of vertexes can be very irregular in my terrains, unless i use the terrain-reshaper 😉 )
                        but first enjoy your holiday!
                        and thanks again for the update 😍
                        • R
                          rv1974
                          Didier thanks for your efforts!
                          One can get interesting things with new vertice mode.
                          http://img212.imageshack.us/img212/6828/screenshot060qi3.jpg
                          [URL=http://g.imageshack.us/g.php?h=212&i=screenshot060qi3.jpg][IMG]http://img212.imag
                          But there's bug in vertex+no to keep vertical . It's not working (see lonely cylinder over mesh, in all other cases components stay vertical)
                          To "keep vertical" unchecked will result the component to be placed vertical to mesh, it'll work this way, right?
                          P.S. I'm not programmer (my wife is- it's enough for one family) but you're one step from "spray along vertices of curve" ? 😉
                          P.P.S. Do you shine in ruby field only or there are some lisp routins of yours?
                          • MALAISEM
                            MALAISE
                            Thanks Didier, faboulous tool
                            MALAISE 😄
                            • plot-parisP
                              plot-paris
                              it is really great.with this new vertex-function the component-spray tool goes far beyond a mere tool for creation of random assemblies of components. you can now use it to accurately place entities, like in the following short example:
                              create a rastered face (with the sanbox tool) and create a component (of a column for example (Gaieus, don't be mad with me because of the colum's base shape - it's not ment to be historically accurate 😄 )
                              http://img293.imageshack.us/img293/6666/compspray1ke3.jpg
                              then delete all the faces arround a shape you want the columns to be placed along and select the remaining faces
                              http://img80.imageshack.us/img80/4869/compspray2yt3.jpg
                              now use the new vertex mode of the component spray tool (make sure, that random rotation is inactive), and you can easily get some nice architectural assemblies
                              http://img293.imageshack.us/img293/6425/compspray3bw6.jpg
                              great, Didier - I love this new tool!!! 😍
                              PS: it is even easy to place components along rounded shapes...
                              http://img293.imageshack.us/img293/1619/compspray4af2.jpg
                              • K
                                kwistenbiebel
                                Didier is da man !
                                Great work! I'll be trying it this week as soon as I find the time.
                                The vertices mode sounds like a very useful option.
                                • M
                                  marcosrodrigues
                                  Thank you, Sir!
                                  | menos é mais
                                  • S
                                    sepo
                                    Wow... This is a very good news.
                                    • FletchF
                                      Fletch
                                      plot-paris... I haven't used this tool yet. 😳 but I've read the 'manual'... and I think you can already select faces and spray only on the faces... like your wish you mention below...
                                      Fletch
                                      3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                                      • W
                                        wyatt
                                        Thanks for the update. I love this script!
                                        Wyatt
                                        • GaieusG
                                          That's a nice one Jacob, indeed! And thanks Didier for the script of course! 👍
                                          • plot-parisP
                                            plot-paris
                                            thanks Gaieus.
                                            oh, and Fletch, you are right. it is already possible. it even automatically chooses the "spray on selection" option, when some faces are selected - so cool! 👍
                                            • 1 / 5
