    [Plugin] Toggle Units
    159 Posts 47 Posters 142.7k Views 47 Watching
    • EdsonE Offline
      Edson
      matt,
      good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem).
      what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick".
      but we made some progress.
      http://www.mahfuz.arq.br
        Matt666
        Wow... Strange!
        Thank you Edson! We will slowly succeed! 😄
        Another request, please... A daunting request...
        Can you open your ruby console and your units window (in model info), please?
        Copy and paste code below in the ruby console
        Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]
        Change unit format, paste the code in the ruby console and give me the result like that :
        Unit format (decimal, Architectural) -> result of the code
        Can You do that for all SU unit Format please? 😛
        The same thing for units length... With this code :
        Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
        Here is units options in SU/Windows :
        Unit Format
        • Architectural -> 1
        • Decimal -> 0
        • Engineering -> 2
        • Fractionnal -> 3
        Unit Length
        • Inches -> 0
        • Feet -> 1
        • Millimeters -> 2
        • Centimeters -> 3
        • Meters -> 4
        Thank you Edson!
        Frenglish at its best !
        My scripts
        • EdsonE Offline
          Edson
          sorry, max. it may seem clear to you but i am not getting what i am supposed to do. lead me through it, ok?
          after i paste Sketchup.active_model.options["UnitsOptions"]["LengthFormat"] what do i do? where do decimal and meters go? with or without quotation marks, etc? and where do i insert the unit options?
          write down one of the options and i will figure out the others.
          cheers.
            Matt666
            Sorry 😳 !
            Procedure :
            For all units format (decimal, architectural, engineering, Fractional) -> N°1 on the picture
            1. Change the format in the unit SU window (N°1)
            2. Copy, paste and excecute the code in the ruby console (N°3)
            1. Show me the result of the code in the ruby console Like my last post.
            For all units length (Inch, feet, millimeters, centimeters, meters) -> N°2 on the picture
            1. Change the length in the unit SU window (N°2)
            If it's too constraining for you, don't hesitate to tell, I understand 😄
            Sorry again, Edson!
            My scripts
            • EdsonE Offline
              Edson
              gotcha! is this it?
                Matt666
                Great ! The only problem is that it's the same thing as Window.... I d'ont understand your (Big) Mac Bug.... 😡 😡 😡
                Thank you Edson!
                My scripts
                  Matt666
                  @edson said:
                  matt,
                  Just one thing... With this update, can you try this : [floatr:22oduved]Sans titre 1.jpg[/floatr:22oduved]
                  1. Draw a line
                  2. Create a dimension entity of this line
                  3. Try to change units in the toolbar...
                    Is the dimension change ?
                    On windows, dimension changes each time you change units...
                  My scripts
                  • EdsonE Offline
                    Edson
                    matt,
                    however, the buttons stay in "pressed" mode even when you change units. check below: after testing the meter button, i clicked on cm and then mm. all of them stayed as if they were active. would there be a way for making only the active unit's button to show as such? Picture 15.png
                      Matt666
                      Ok cool! Thank you!
                      Do you have any error in the ruby console?
                      My scripts
                      • EdsonE Offline
                        Edson
                        no errors.
                        • kenK Offline
                          ken
                          Sir
                          Matt666 your Plugin Toggle Units is very useful and I use it all the time when I get marine vessels in metric and diving equipment in Imperial.
                          Just one question, would it be possible to add up and down precision buttons, so with a mouse selection, one could change the precision of the display either up or down as required?
                          Thanks in advance and again thanks for the very useful plugin.
                          Ken
                            Matt666
                            Hi Ken.
                            in the first post, a new tool has been added. The last with 11 icons.
                            Enjoy !
                            My scripts
                            • CadFatherC Offline
                              CadFather
                              Hi Matt, will do some new icons soon for all eleven (didn't like the other ones) 😄
                                Matt666
                                Cool!
                                My scripts
                                • kenK Offline
                                  ken
                                  Hi Matt
                                  Thanks. As you can see from my avatar, I design in flat steel plate, and 1/8” is close enough for welders.
                                  Your response was faster service than I had at the restaurant I just returned from. Hope others find this helpful.
                                  Again much thanks.
                                  And on a side note, my youngest daughter is trying to be an exchange student to France this summer. She is taking French in HS this year. I know if she gets to go, she will have a great time.
                                  Again thanks
                                  Ken
                                    Matt666
                                    Sure! 😄
                                    Where will she want to go in France?
                                    My scripts
                                    • kenK Offline
                                      ken
                                      Matt
                                      See will find out in the next two weeks if she is accepted and where exactly where she is going.
                                      Thanks for asking
                                      Ken
                                        Matt666
                                        I've updated first post with a new tool and new icons by CadFather! Thank you Max!
                                        Edson or Thomthom, does this version work on Mac?
                                        My scripts
                                        • EdsonE Offline
                                          Edson
                                          i am afraid only the three added features work. the rest does not (but was working perfectly before). no error in the ruby console.
                                            Matt666
                                            Incredible... That's incredible! Cheer up! We will success...
                                            My scripts
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
