    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
      Matt666
      Yep! On Fedo6 advices, I changed the way that script called preferences units...
      So we have to try some things...
      Open your ruby console, copy and paste code below and can you show me the result please ?
      toggle_units(1)
      And
      Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
      And
      var = Sketchup.active_model.options["UnitsOptions"];var["LengthUnit"]= 4
      And this one (can you replace "VAR" by result of the last code entered, please ?
      toggle_units_validation_proc(<VAR>)
      Another thing : When does error message appears? While start of SU? After clicking on an icon?
      Sorry for all these tests, but it's necessary if I want to find the problem!
      Thank you Edson!
      Frenglish at its best !
      My scripts
      • EdsonE
        Edson
        matt,
        do no be sorry. just keep the tests coming.
        see the results in the attached picture. i do not get any error messages. it just does not change units.
        cheers.
        http://www.mahfuz.arq.br
          Matt666
          😲 toggle_units(1) works!! Try toggle_units(1), toggle_units(2), toggle_units(3) etc... And take a look in the units window (Windows->Model info->Units), normally drawing unit changes...
          So I will post an update soon with toolbar code changed! Thank you Edson !
          My scripts
            Matt666
            @edson said:
            no change, matt. still not working on mac. i click on the icons and nothing changes; it keeps the unit set through model info-->units.
            Hi !
            I go back on this plugin, with another attempt for Mac users. Edson, Can you try please? πŸ˜‰
            EDIT1 : One other (And I hope the last !) update!
            toggle_units.zip
            My scripts
              Matt666
              Ok, I've finished this update! Can you try it, Edson, please? Thank you!
              My scripts
              • EdsonE
                Edson
                matt,
                good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem).
                what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick".
                but we made some progress.
                  Matt666
                  Wow... Strange!
                  Thank you Edson! We will slowly succeed! πŸ˜„
                  Another request, please... A daunting request...
                  Can you open your ruby console and your units window (in model info), please?
                  Copy and paste code below in the ruby console
                  Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]
                  Change unit format, paste the code in the ruby console and give me the result like that :
                  Unit format (decimal, Architectural) -> result of the code
                  Can You do that for all SU unit Format please? πŸ˜›
                  The same thing for units length... With this code :
                  Here is units options in SU/Windows :
                  Unit Format
                  • Architectural -> 1
                  • Decimal -> 0
                  • Engineering -> 2
                  • Fractionnal -> 3
                  Unit Length
                  • Inches -> 0
                  • Feet -> 1
                  • Millimeters -> 2
                  • Centimeters -> 3
                  • Meters -> 4
                  Thank you Edson!
                  My scripts
                  • EdsonE
                    Edson
                    sorry, max. it may seem clear to you but i am not getting what i am supposed to do. lead me through it, ok?
                    after i paste Sketchup.active_model.options["UnitsOptions"]["LengthFormat"] what do i do? where do decimal and meters go? with or without quotation marks, etc? and where do i insert the unit options?
                    write down one of the options and i will figure out the others.
                    cheers.
                      Matt666
                      Sorry 😳 !
                      Procedure :
                      For all units format (decimal, architectural, engineering, Fractional) -> NΒ°1 on the picture
                      1. Change the format in the unit SU window (NΒ°1)
                      2. Copy, paste and excecute the code in the ruby console (NΒ°3)
                      1. Show me the result of the code in the ruby console Like my last post.
                      For all units length (Inch, feet, millimeters, centimeters, meters) -> NΒ°2 on the picture
                      1. Change the length in the unit SU window (NΒ°2)
                      If it's too constraining for you, don't hesitate to tell, I understand πŸ˜„
                      Sorry again, Edson!
                      My scripts
                      • EdsonE
                        Edson
                        gotcha! is this it?
                          Matt666
                          Great ! The only problem is that it's the same thing as Window.... I d'ont understand your (Big) Mac Bug.... 😑 😑 😑
                          Thank you Edson!
                          My scripts
                            Matt666
                            @edson said:
                            matt,
                            Just one thing... With this update, can you try this : [floatr:22oduved]Sans titre 1.jpg[/floatr:22oduved]
                            1. Draw a line
                            2. Create a dimension entity of this line
                            3. Try to change units in the toolbar...
                              Is the dimension change ?
                              On windows, dimension changes each time you change units...
                            My scripts
                            • EdsonE
                              Edson
                              matt,
                              however, the buttons stay in "pressed" mode even when you change units. check below: after testing the meter button, i clicked on cm and then mm. all of them stayed as if they were active. would there be a way for making only the active unit's button to show as such? Picture 15.png
                                Matt666
                                Ok cool! Thank you!
                                Do you have any error in the ruby console?
                                My scripts
                                • EdsonE
                                  Edson
                                  no errors.
                                  • kenK
                                    ken
                                    Sir
                                    Matt666 your Plugin Toggle Units is very useful and I use it all the time when I get marine vessels in metric and diving equipment in Imperial.
                                    Just one question, would it be possible to add up and down precision buttons, so with a mouse selection, one could change the precision of the display either up or down as required?
                                    Thanks in advance and again thanks for the very useful plugin.
                                    Ken
                                      Matt666
                                      Hi Ken.
                                      in the first post, a new tool has been added. The last with 11 icons.
                                      Enjoy !
                                      My scripts
                                      • CadFatherC
                                        CadFather
                                        Hi Matt, will do some new icons soon for all eleven (didn't like the other ones) πŸ˜„
                                          Matt666
                                          Cool!
                                          My scripts
                                          • kenK
                                            ken
                                            Hi Matt
                                            Thanks. As you can see from my avatar, I design in flat steel plate, and 1/8” is close enough for welders.
                                            Your response was faster service than I had at the restaurant I just returned from. Hope others find this helpful.
                                            Again much thanks.
                                            And on a side note, my youngest daughter is trying to be an exchange student to France this summer. She is taking French in HS this year. I know if she gets to go, she will have a great time.
                                            Again thanks
                                            Ken
                                            • 3 / 8
