    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
    • EdsonE Offline
      Edson
      gotcha! is this it?
      http://www.mahfuz.arq.br
        Matt666
        Great ! The only problem is that it's the same thing as Window.... I d'ont understand your (Big) Mac Bug.... 😑 😑 😑
        Thank you Edson!
        Frenglish at its best !
        My scripts
          Matt666
          @edson said:
          matt,
          good news from the mac side of life. it works. however, in order to see the change in the info panel i must close it and open it again (not a big problem).
          what could be improved is the fact that the icon bar does not reflect the present units chosen. see the picture: i have decimal and centimeters on it but the icon bar is not reflecting it. sometimes it is all gray, others white. the buttons seem to "stick".
          but we made some progress.
          Just one thing... With this update, can you try this : [floatr:22oduved]Sans titre 1.jpg[/floatr:22oduved]
          1. Draw a line
          2. Create a dimension entity of this line
          3. Try to change units in the toolbar...
            Is the dimension change ?
            On windows, dimension changes each time you change units...
          My scripts
          • EdsonE Offline
            Edson
            matt,
            however, the buttons stay in "pressed" mode even when you change units. check below: after testing the meter button, i clicked on cm and then mm. all of them stayed as if they were active. would there be a way for making only the active unit's button to show as such? Picture 15.png
              Matt666
              Ok cool! Thank you!
              Do you have any error in the ruby console?
              My scripts
              • EdsonE Offline
                Edson
                no errors.
                • kenK Offline
                  ken
                  Sir
                  Matt666 your Plugin Toggle Units is very useful and I use it all the time when I get marine vessels in metric and diving equipment in Imperial.
                  Just one question, would it be possible to add up and down precision buttons, so with a mouse selection, one could change the precision of the display either up or down as required?
                  Thanks in advance and again thanks for the very useful plugin.
                  Ken
                    Matt666
                    Hi Ken.
                    in the first post, a new tool has been added. The last with 11 icons.
                    Enjoy !
                    My scripts
                    • CadFatherC Offline
                      CadFather
                      Hi Matt, will do some new icons soon for all eleven (didn't like the other ones) πŸ˜„
                        Matt666
                        Cool!
                        My scripts
                        • kenK Offline
                          ken
                          Hi Matt
                          Thanks. As you can see from my avatar, I design in flat steel plate, and 1/8” is close enough for welders.
                          Your response was faster service than I had at the restaurant I just returned from. Hope others find this helpful.
                          Again much thanks.
                          And on a side note, my youngest daughter is trying to be an exchange student to France this summer. She is taking French in HS this year. I know if she gets to go, she will have a great time.
                          Again thanks
                          Ken
                            Matt666
                            Sure! πŸ˜„
                            Where will she want to go in France?
                            My scripts
                            • kenK Offline
                              ken
                              Matt
                              See will find out in the next two weeks if she is accepted and where exactly where she is going.
                              Thanks for asking
                              Ken
                                Matt666
                                I've updated first post with a new tool and new icons by CadFather! Thank you Max!
                                Edson or Thomthom, does this version work on Mac?
                                My scripts
                                • EdsonE Offline
                                  Edson
                                  i am afraid only the three added features work. the rest does not (but was working perfectly before). no error in the ruby console.
                                    Matt666
                                    Incredible... That's incredible! Cheer up! We will success...
                                    My scripts
                                    • kenK Offline
                                      ken
                                      Matt
                                      Installed and works as advertised. Also, like the additional button.
                                      Thank you.
                                      Ken
                                      • JClementsJ Offline
                                        JClements
                                        Ahhhh ... changed already. I added a red dot to the original set to show the association between related buttons.
                                        CAD father's, as always, are nice icons.
                                        John
                                          Matt666
                                          Sorry JClements... 😳 😳 😳
                                          My scripts
                                            JClements
                                            Hey Matt:
                                            Could the new values created when the accuracy buttons are clicked, be displayed somewhere such as in the Task Bar or better yet when the mouse is put over the top of button?
                                            John
                                            • 3 / 8
