    Help! Sketchup files look terrible in Layout?
    layout
    5 Posts 3 Posters 2.6k Views 3 Watching
      trc1963
      I dont know what is going on??? I have a floor plan in Sketchup it looks ok in Sketchup, but when I insert it into layout the quality is so poor it looks terrible, when I zoom in on my sketchup model in layout the line thickness is about a foot thick (in Scale)... Whats going on? I have the resolution set to 300 in sketchup. I think I attached the correct file showing this.
      Thanks Terry
      Del Sol Rear hardscape After Drawing.skp
      • ToboboT Offline
        Tobobo
        Layout optimises the view to speed things up while you are working on it. you also can assign line thickness to the windows.
        Toby
        Philippians 4:13
          trc1963
          thank you Tobi,
          It's amazing how someone can spend hrs looking for something and it's right there in tiny little box!
          • ToboboT Offline
            Tobobo
            No problem mate.
            Post some stuff when your done so we can see your work
            Toby
            Philippians 4:13
            • cmdC Offline
              cmd
              Just to point out an item that Tobobo mentioned above, Layout has settings to allow you to design and arrange your models at a low res state, to allow for better performance, and export at a higher dpi/res.
              All this is done through the Document Setup/Paper... Rendering. See attached image
              Cheers
              CMD
              Layout Rendering Level Options
              • CMD
