ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Help! Sketchup files look terrible in Layout?
layout
5 Posts 3 Posters 2.4k Views
    trc1963
    I dont know what is going on??? I have a floor plan in Sketchup it looks ok in Sketchup, but when I insert it into layout the quality is so poor it looks terrible, when I zoom in on my sketchup model in layout the line thickness is about a foot thick (in Scale)... Whats going on? I have the resolution set to 300 in sketchup. I think I attached the correct file showing this.
    Thanks Terry
    Del Sol Rear hardscape After Drawing.skp
      Tobobo
      Layout optimises the view to speed things up while you are working on it. you also can assign line thickness to the windows.
      Toby
      Philippians 4:13
        trc1963
        thank you Tobi,
        It's amazing how someone can spend hrs looking for something and it's right there in tiny little box!
          Tobobo
          No problem mate.
          Post some stuff when your done so we can see your work
          Toby
          Philippians 4:13
            cmd
            Just to point out an item that Tobobo mentioned above, Layout has settings to allow you to design and arrange your models at a low res state, to allow for better performance, and export at a higher dpi/res.
            All this is done through the Document Setup/Paper... Rendering. See attached image
            Cheers
            CMD
            Layout Rendering Level Options
            • CMD
