    [Plugin] Terrain Reshaper
    48 Posts 34 Posters 70.8k Views 34 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      The excellent method to "reshape" a terrain by Plot-Paris has been implemented in this beta version (French version also available soon). Quick start PDF included.
      Feedback welcome !
      Enjoy,
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=terrain_reshaper
      Unzip in your Plugins folder. Read PDF plz.
      DB
      • P Offline
        pav_3j
        wow, thank you very much didier!
        and thank you plot-paris, wherever you may be!
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • plot-parisP Offline
          plot-paris
          Didier, this is marvellous! thank you so much! 😍
          some observations after a first short try.
          after completion of the process you have to smooth the terrain manually (context click > soften/smooth edges). does it make sense to automate this process or would that bring disadvantages? 😕
          indeed, with the "merge coplanar faces" function you are likely to use some faces, especially near the border.
          really great is, that the borders are maintained - thus the reshaped terrain does still perfectly fit into surrounding geometry. 👍
          what would be great: if holes in a terrain would be cept. but thats probably the same mentioned issue you want to fix in the next release (if you do succeed in fixing it, you are one step ahead of SketchUp's from contours function 😉 ).
          http://img329.imageshack.us/img329/4944/regularterrainvn1.jpg
          • alexschreyerA Offline
            alexschreyer Extension Creator
            Great plugin! Looking forward to trying this out. Maybe this could be the start of a panelizing plugin as well (similar to the Rhino version). At this point it seems to implement a regular grid on the projected surface. Would it be possible to re-use code from the "lines on surface" plugin to make it possible to apply a grid directly to the surface?
            Author of "Architectural Design with SketchUp":
            http://sketchupfordesign.com/
            • I Offline
              ilay7k
              Thank you!
              • EdsonE Offline
                Edson
                great work, didier! you --and a few other ruby coders-- are taking SUp to a very high level.
                regards.
                http://www.mahfuz.arq.br
                  marcosrodrigues
                  @alexschreyer said:
                  (...) Maybe this could be the start of a panelizing plugin as well (similar to the Rhino version) (...)
                  | menos é mais
                    Didier Bur
                    Exactly: faces outside borders and in "former holes" will be removed automatically.
                    That's very easy to do by script but IMHO this will have to be an option of the dialog box, I don't intend the user to have a smoothed/soften terrain if he doesn't want to.
                    Call me stupid but I don't know what a 'panelize' operation is ?
                    DB
                    • I Offline
                      ilay7k
                      http://en.wiki.mcneel.com/default.aspx/McNeel/PanelingCommands.html
                      • I Offline
                        ilay7k
                        sorry 😒
                        it will be nice to see grasshopper-like plugin too - http://grasshopper.rhino3d.com/
                          marcosrodrigues
                          c'est pas grave, Didier 😄 not a problem
                          I used it to do this: http://farm4.static.flickr.com/3104/2672948946_b41ed61d61_b.jpg
                          oh, you beat me, Ilya 😉
                          | menos é mais
                            Didier Bur
                            OK, I'm less stupid now than this morning 😎
                            DB
                              cyan.archnet
                              Marvelous plugin, THANKS A LOT!
                              • urgenU Offline
                                urgen
                                ...thanks Didier,very useful! 👍
                                --pupil forever...------
                                • jujuJ Offline
                                  juju
                                  Didier, you're the MAN! thumps chest twice with thumb side of fist
                                  The smoothing can be done with Matt666's smoothing plugin, should work like a charm...
                                    chango70
                                    Man u are the reason Sketchup is half as cool as it is for me! Keep it up!
                                      boerenkool
                                      Mille grazie !
                                        redot
                                        Thanks Didier. Great plugin
                                          plot-paris
                                          hi Didier,
                                          I just wanted to clean up a terrain. I used the options
                                          -create group: yes
                                          -delete original: yes
                                          -merge faces: no
                                          -size 600mm
                                          when it was finished it looked like this
                                          http://img172.imageshack.us/img172/8200/meshmessij3.jpg
                                          the original terrain had not been deleted. but the new terrain was incomplete where the old mesh was visible (see image above). no idea, why it didnt work. just thought I would tell, in case you have a clue. 😉
                                            Didier Bur
                                            Fredo6,Matt666 and me, the french connection 🤣
                                            @Plot-paris:
                                            Could you PM me the SKP file ? I'm curious to know what bug's still there 🎉
                                            DB
                                            • 1 / 3
