    [Plugin] Terrain Reshaper
    48 Posts 34 Posters 69.7k Views 34 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Great plugin! Looking forward to trying this out. Maybe this could be the start of a panelizing plugin as well (similar to the Rhino version). At this point it seems to implement a regular grid on the projected surface. Would it be possible to re-use code from the "lines on surface" plugin to make it possible to apply a grid directly to the surface?
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • I Offline
        ilay7k
        Thank you!
        • EdsonE Offline
          Edson
          great work, didier! you --and a few other ruby coders-- are taking SUp to a very high level.
          regards.
          http://www.mahfuz.arq.br
            marcosrodrigues
            @alexschreyer said:
            (...) Maybe this could be the start of a panelizing plugin as well (similar to the Rhino version) (...)
            | menos é mais
            • Didier BurD Offline
              Didier Bur
              thats probably the same mentioned issue you want to fix in the next release
              Exactly: faces outside borders and in "former holes" will be removed automatically.
              does it make sense to automate this process
              That's very easy to do by script but IMHO this will have to be an option of the dialog box, I don't intend the user to have a smoothed/soften terrain if he doesn't want to.
              Call me stupid but I don't know what a 'panelize' operation is ?
              DB
              • I Offline
                ilay7k
                http://en.wiki.mcneel.com/default.aspx/McNeel/PanelingCommands.html
                • I Offline
                  ilay7k
                  sorry 😒
                  it will be nice to see grasshopper-like plugin too - http://grasshopper.rhino3d.com/
                    marcosrodrigues
                    c'est pas grave, Didier 😄 not a problem
                    I used it to do this: http://farm4.static.flickr.com/3104/2672948946_b41ed61d61_b.jpg
                    oh, you beat me, Ilya 😉
                    | menos é mais
                      Didier Bur
                      OK, I'm less stupid now than this morning 😎
                      DB
                        cyan.archnet
                        Marvelous plugin, THANKS A LOT!
                        • urgenU Offline
                          urgen
                          ...thanks Didier,very useful! 👍
                          --pupil forever...------
                          • jujuJ Offline
                            juju
                            Didier, you're the MAN! thumps chest twice with thumb side of fist
                            The smoothing can be done with Matt666's smoothing plugin, should work like a charm...
                              chango70
                              Man u are the reason Sketchup is half as cool as it is for me! Keep it up!
                                boerenkool
                                Mille grazie !
                                  redot
                                  Thanks Didier. Great plugin
                                  • plot-parisP Offline
                                    plot-paris
                                    hi Didier,
                                    I just wanted to clean up a terrain. I used the options
                                    -create group: yes
                                    -delete original: yes
                                    -merge faces: no
                                    -size 600mm
                                    when it was finished it looked like this
                                    http://img172.imageshack.us/img172/8200/meshmessij3.jpg
                                    the original terrain had not been deleted. but the new terrain was incomplete where the old mesh was visible (see image above). no idea, why it didnt work. just thought I would tell, in case you have a clue. 😉
                                      Didier Bur
                                      Fredo6,Matt666 and me, the french connection 🤣
                                      @Plot-paris:
                                      Could you PM me the SKP file ? I'm curious to know what bug's still there 🎉
                                      DB
                                        And if Ruby was my cup of tea, that will the The Four Musketeers! 🤣
                                          REGIS
                                          And if Ruby was my cup of tea, that will the "club des cinq" 🤣
                                          @Plot-paris:
                                          Can you show us or share the starting idea, I would like to see before you apply model with contours.(perhaps I've got an idea using your technic to model terrain).
                                          After a few tests using different methods, I let you guess
                                          who's who.
                                          regards
                                            plot-paris
                                            good morning REGIS,
                                            the initial idea was discussed in this thread.
                                            for the who is who test - could you give us some multiple choice answers? 😉
                                            • 1 / 3
