    [Plugin] Terrain Reshaper
    48 Posts 34 Posters 72.1k Views 34 Watching
      marcosrodrigues
      c'est pas grave, Didier 😄 not a problem
      http://en.wiki.mcneel.com/default.aspx/McNeel/PanelingCommands.html
      I used it to do this: http://farm4.static.flickr.com/3104/2672948946_b41ed61d61_b.jpg
      oh, you beat me, Ilya 😉
      | menos é mais
      • Didier BurD
        Didier Bur
        OK, I'm less stupid now than this morning 😎
        DB
        • C
          cyan.archnet
          Marvelous plugin, THANKS A LOT!
          • urgenU
            urgen
            ...thanks Didier,very useful! 👍
            --pupil forever...------
            • jujuJ
              juju
              Didier, you're the MAN! thumps chest twice with thumb side of fist
              The smoothing can be done with Matt666's smoothing plugin, should work like a charm...
              • C
                chango70
                Man u are the reason Sketchup is half as cool as it is for me! Keep it up!
                • B
                  boerenkool
                  Mille grazie !
                    redot
                    Thanks Didier. Great plugin
                    • plot-parisP
                      plot-paris
                      hi Didier,
                      I just wanted to clean up a terrain. I used the options
                      -create group: yes
                      -delete original: yes
                      -merge faces: no
                      -size 600mm
                      when it was finished it looked like this
                      http://img172.imageshack.us/img172/8200/meshmessij3.jpg
                      the original terrain had not been deleted. but the new terrain was incomplete where the old mesh was visible (see image above). no idea, why it didnt work. just thought I would tell, in case you have a clue. 😉
                      • Didier BurD
                        Didier Bur
                        Fredo6,Matt666 and me, the french connection 🤣
                        @Plot-paris:
                        Could you PM me the SKP file ? I'm curious to know what bug's still there 🎉
                        DB
                          And if Ruby was my cup of tea, that will the The Four Musketeers! 🤣
                            REGIS
                            And if Ruby was my cup of tea, that will the "club des cinq" 🤣
                            @Plot-paris:
                            Can you show us or share the starting idea, I would like to see before you apply model with contours.(perhaps I've got an idea using your technic to model terrain).
                            After a few tests using different methods, I let you guess
                            who's who.
                            regards
                            • plot-parisP
                              plot-paris
                              good morning REGIS,
                              the initial idea was discussed in this thread.
                              for the who is who test - could you give us some multiple choice answers? 😉
                              • P
                                putnik
                                Didier, amazingly useful tool! Thanks so much! Thank you plot-paris and everyone else from this topic for this most excellent idea
                                http://keshas.info
                                • P
                                  putnik
                                  Didier, don't know if it's possible to do, but it would be helpful (me thinks) if the the script somehow retained the information collected at the "Parsing terrain.." stage, in case one wants to reshape the terrain again with, say, differently sized triangles.
                                  http://keshas.info
                                    johnnybfunk
                                    Hey,
                                    I've imported 6-7 GE terrain meshes, exploded them, put them all in a group, and then tried to run didier's plugin. 😐 It didn't come out as expected.
                                    The problem is, i think, that i didn't really merge the different meshes before runnig the script, and that all 6 or 7 of them reacted as independent meshes.
                                    Does anybody have a quick and easy solution for stitching together different meshes imported from GE?
                                    Thank you,
                                    Félix
                                    • Chris FullmerC
                                      Hi Felix, I think that the problem is just that you need to select all the terrains you want to reshape and turn them into a single group. Then just select the 1 group and run the plugin. It will not accept a selection of loose geometry. Only a single group.
                                      Hope that helps,
                                      • JClementsJ
                                        JClements
                                        Didier:
                                        Suggestion/Request
                                        When dealing with a large terrain surface, the Parsing, Triangulation, and Merging functions of the script can take quite a while.
                                        I was wondering if at the end of each function (before the user goes to the next) if an elapsed time could be shown. At the completion of the script, then a final dialog would be displayed showing the elapsed time of each function.
                                        This way, if you had to convert a series of similar terrains, you wouldn't have to wait around at your computer ... just go do something else and come back according the to elapsed times of the first reshaping session. 😄
                                        • olisheaO
                                          olishea
                                          effing fantastic plugin. i could have done with this a few weeks back, works great
                                          oli
                                          • plot-parisP
                                            plot-paris
                                            sometimes, when you have got a terrain with a lot of detail in places and very little information in others, the terrain reshaper has to be set according to the highest level of detail. that results in models with unnecessarily large numbers of vertexes.
                                            therefore the idea for an improved plugin - the Dynamic Terrain Reshaper! you define a maximum vertex size and a minimum vertex size. then the plugin calculates the whole terrain with the large vertices and subdivides, where neccessary, until it reaches the minimum vertex size limit.
                                            was that comprehensible?
                                            • 1 / 3
