    Mixed Media Output
    extensions
    9 Posts 5 Posters 1.5k Views 5 Watching
    • B
      bytor
      Hello,
      Is there a method for being able to export an image of just the linework from SU to mix with the Kery rendered output. I have attached an image I am playing with where I have layered and adjusted two different Kerky outputs together and would like to add a skechy line effect to it as well. I can't seem to get the same / aspect image if I try to export an image from SU.
      Is anybody doing this? And if so - could you show an example and explain how please.
      Thanks,
      Bytor
      Find the Cost of Freedom.....
      • FrederikF
        Frederik
        On the frontpage of the Getting Started - KT2008 Echo tutorial, you can see an image made using a KT render and a direct SU export merged together... πŸ˜‰
        It's very simple to do actually...
        As you may know, the scenes you create in SU will get exported as camera positions in KT...
        So if you export a 2D graphic from SU and you render the same scene in KT, you'll get identical images, which you can merge in a post pro... πŸ˜‰
        Cheers
        Kim Frederik
        • J
          Jon
          Following Frederik's reply, if you changed the position of your camera within Kerkythea to a different location than what you had in Sketchup, you can export your scene again with a different name. Now in Kerkythea, you can use 'File > Merge' to merge your new camera with your model. Simply change every tab except the "cameras" tab to "Keep current - throw new away". For cameras, select "merge - add to current" and look for the scene you just exported. Now you should have your old scene with your new cameras. πŸ˜‰
          Jon
          KT Team member
          • B
            bytor
            Kim & Jon,
            Thanks both of you for your help. I didn't keep this SU model and view after I exported because I delete a wa;; to get the view I wanted to work with. I did test what you taught me on another image that is posted in the Gallery section here. I see this as just another fun way to use Kerky, and I will experiment a lot more on some other interiors I need to produce soon.
            Thanks again!
            Bytor
            • L
              lapx
              Im having trouble getting identical images. I exported with same camera. Overlay in photoshop should be the same but not.
              What could be wrong?
              • L
                lapx
                Got it ot work for a single exported render image in kerky. Did not work for batch render images for some reason.
                • GaieusG
                  To be honest, I have never been able to export the exact same camera (FOV mainly) into Kerky. I first realized this when I was trying to make cubic panoramas. Then I found a topic on the Kerky forums where someone posted the same pains about those cubic panoramas and there were the settings but I cannot remember where that post is or what the settings are.
                  Have you got Twilight by any chance? That can export the same cameras to Kerky.
                  • L
                    lapx
                    Is there any way to compare the cameras position and FOV in kerkythea and sketchup?
                    I noted on the kerkythea forum that I was mistaken and upon closer review i didnt get a perfect match.
                    havent dicovered what is going wrong. 😞
                    • GaieusG
                      Can you post your model (or upload somewhere)?
