    [TUTORIAL] Making holes through pipe (cylinder)
    21 Posts 10 Posters 9.0k Views 10 Watching
      basic.woodworks
      For sake of practice on my part and as per a request from a post, I created this simple tutorial to show how to create holes through a cylinder. Note that this method as been described numerous times and to more experienced user it may seem silly to post it but, I hope, new users may learn something from it.
      Best regards.
      Mike RL
      The delays have been re-set to a longer period allowing the viewer to better read the captions and examine the drawings better.
      "The greatest mistake a person can make is to be afraid of making one." (Elbert Hubbard)
      • W Offline
        watkins
        Dear Mike,
        Your tutorial is instructive on a more advanced level if the reader first opens up the Layers and Scenes dialogue boxes and then activates show "section planes", and all before starting the tutorial at Introduction.
        Regards,
        Bob
          It is a very nicely performed tut, Mike! 👍
          Thanks for the care!
            basic.woodworks
            Thanks for the feedback guys. It's nice to get a pat on the back from time to time and feel usefull.
            I showed to a friend to get his input and we ended up changing the time delays to better the reading time and examination of the drawings. Is there a way that I can update the uploaded file?
            Thanks again
            Mike RL
              Mike, you can always edit your own posts and delete files from it and uplo9ad new attachments. (At least I think you can - I can do it with anyone's posts but maybe only because I'm special 😳 Just tell me if you need help - or post your revised tut in a PM if you cannot change it).
                basic.woodworks
                Thank you for the tip Gieus.
                I selected "view my posts" and the option to edit was prominent. I clicked on it and was able to reword the message, alter the comment to the attachment, delete the file and attach the revised version.
                Thanks AGAIN for your wisdom. I'm very grateful. 😍
                Regards
                Mike RL
                • boofredlayB Offline
                  boofredlay
                  Nice Mike, thanks.
                  • MALAISEM Offline
                    MALAISE
                    Hay, basic.woodwork
                    Could you explain how do you use the Push-Pull tool to create that growing****cylinders in the tuto. I'm quite interested in your know-how, it could open new ways for animations...
                    Thanks very much for attention. 👍
                    MALAISE 😉
                    • simon le bonS Offline
                      simon le bon
                      Hi Mike,
                      My question is not on the making holes tut itself but rather on how you made:
                      • to have those text explanations written on the bottom independantly from the animations
                      • to have only one figure, evoluting from scene to scene
                      ??? " le résultat est vraiment pas mal!!!"
                      Simon.
                        basic.woodworks
                        @simon le bon said:
                        Hi Mike,
                        Simon.
                        Hey Simon,
                        If you have downloaded the file, dissect and analyze it. Look at each scene and see what layers are used to crate it. Also, toggle the section planes on and off.
                        Thanks for the compliment.
                        Mike RL
                        PS for more discussion on this, you can contact me directly if you wish.
                        basic.woodworks on Skype
                          simon le bon
                          Hi Mike,
                          It's too late for tonight, and i'm living early in the morning for 15 days without web access 😞
                          I have understood your clever layer use, but i'm still not understanding the animation of your just one evolutive figure.. be back in 15
                          Regards simon.
                            basic.woodworks
                            @malaise said:
                            Hay, basic.woodwork
                            MALAISE 😉
                            If you dissect the model, check out the layers, components and turn on the section planes(there should be a button on the top toolbar for that purpose), you should be able to figure it out. By toggling section planes on and off between scenes it gives the illusion of the"growing" pipes.
                            Hope this helps you
                            Mike RL
                            • O Offline
                              outersketcher
                              From a newbie who is desperately watching every tutorial he can get, I thank you and commend you for a beautifully executed and well thought out tutorial. You helped me..
                              David
                              "I mostly enjoy not being dead.." -Grandpa
                                basic.woodworks
                                David
                                Wow! Thank David. I never thought this little tut would attract any attention. It really nice to help someone and get a pat on the back from so many others. I'm really glad this helped you.
                                Have a great day.
                                Mike RL
                                  Maverick83
                                  Hi basic.woodworks
                                  Nice tut but why have you turned the main cylinder into a group if you have to explode it later on?
                                  Bye bye - Ciao
                                    basic.woodworks
                                    in order to use "section plane", I had to make it a group. but later on, I need to see the whole in it. Had I altered the main tube, it would have wholes in it at the beginning of the tut, thus the 2 similar pipes.
                                    I hope this answers your question.
                                    Regards
                                    Mike RL
                                      RegH
                                      Add me to your list of admirers- a very neat and well thought-out tutorial.
                                      Just a little feedback:
                                      A- On my little LCD monitor (1024 x 768 display)the explanatory text is chopped off at the right end on the longer lines.
                                      B- I think the title could be "Making holes through a solid cylinder". I would like to see you make the cylinder a hollow tube, and make the "cross perforations" appear to be as if a hollow pipe had holes drilled through the sides.
                                      Of course, I may be missing something, maybe my settings?
                                      Again- thanks for the nice work 👍
                                      Edit: Checked it on my laptop (1440 x 900) and got better display, although text still seems to be biased toward right side of screen. Hope I don't seem to picky, just feedback. 😄
                                        basic.woodworks
                                        The principle of a hollow tube is the exact same. I'm assuming that you would like to have a visible wall thickness?!?
                                        When you draw you're pipe, you need to know the i.d. or o.d of it and wall thickness. so draw a circle of the diameter you know and use the offset tool in which ever direction and type in the thickness measurement, hit enter and simply delete the inner face (inside the pipe outline) then use the push/pull tool or create a path for the follow me tool with the line and arc tools. The rest is all the same.
                                        Mike RL
                                          MT3d
                                          great tutorial.. thanx
                                            Hi Rich,
                                            Those tabs are for the step-by-step scenes in the tutorial. When you click on the next tab, you should be "taken" to the next scene that explains the next step.
                                            As for your display problem, try this: Go to Window (Sketchup on Mac) > Preferences > OpenGL settings and try to fiddle aound the different checkboxes.
                                            Most probably there is an issue with your video card/driver (if it's a laptop, maybe you have an integrated chipset on it which is not good news).
                                            Disabling Hardware acceleration may help you but then SU will be slower. Try to update your video driver (or get a edicatd video card).
                                            • 1 / 2
