    [TUTORIAL] Making holes through pipe (cylinder)
    21 Posts 10 Posters 10.9k Views 10 Watching
    • GaieusG
      Mike, you can always edit your own posts and delete files from it and uplo9ad new attachments. (At least I think you can - I can do it with anyone's posts but maybe only because I'm special 😳 Just tell me if you need help - or post your revised tut in a PM if you cannot change it).
      • B
        basic.woodworks
        Thank you for the tip Gieus.
        I selected "view my posts" and the option to edit was prominent. I clicked on it and was able to reword the message, alter the comment to the attachment, delete the file and attach the revised version.
        Thanks AGAIN for your wisdom. I'm very grateful. 😍
        Regards
        Mike RL
        "The greatest mistake a person can make is to be afraid of making one." (Elbert Hubbard)
        • boofredlayB
          boofredlay
          Nice Mike, thanks.
          • MALAISEM
            MALAISE
            Hay, basic.woodwork
            Could you explain how do you use the Push-Pull tool to create that growing****cylinders in the tuto. I'm quite interested in your know-how, it could open new ways for animations...
            Thanks very much for attention. 👍
            MALAISE 😉
            • simon le bonS
              simon le bon
              Hi Mike,
              My question is not on the making holes tut itself but rather on how you made:
              • to have those text explanations written on the bottom independantly from the animations
              • to have only one figure, evoluting from scene to scene
              ??? " le résultat est vraiment pas mal!!!"
              Simon.
              • B
                basic.woodworks
                @simon le bon said:
                Hi Mike,
                Simon.
                Hey Simon,
                If you have downloaded the file, dissect and analyze it. Look at each scene and see what layers are used to crate it. Also, toggle the section planes on and off.
                Thanks for the compliment.
                Mike RL
                PS for more discussion on this, you can contact me directly if you wish.
                basic.woodworks on Skype
                • simon le bonS
                  simon le bon
                  Hi Mike,
                  It's too late for tonight, and i'm living early in the morning for 15 days without web access 😞
                  I have understood your clever layer use, but i'm still not understanding the animation of your just one evolutive figure.. be back in 15
                  Regards simon.
                  • B
                    basic.woodworks
                    @malaise said:
                    Hay, basic.woodwork
                    MALAISE 😉
                    If you dissect the model, check out the layers, components and turn on the section planes(there should be a button on the top toolbar for that purpose), you should be able to figure it out. By toggling section planes on and off between scenes it gives the illusion of the"growing" pipes.
                    Hope this helps you
                    Mike RL
                    • O
                      outersketcher
                      From a newbie who is desperately watching every tutorial he can get, I thank you and commend you for a beautifully executed and well thought out tutorial. You helped me..
                      David
                      "I mostly enjoy not being dead.." -Grandpa
                      • B
                        basic.woodworks
                        David
                        Wow! Thank David. I never thought this little tut would attract any attention. It really nice to help someone and get a pat on the back from so many others. I'm really glad this helped you.
                        Have a great day.
                        Mike RL
                          Maverick83
                          Hi basic.woodworks
                          Nice tut but why have you turned the main cylinder into a group if you have to explode it later on?
                          Bye bye - Ciao
                          • B
                            basic.woodworks
                            in order to use "section plane", I had to make it a group. but later on, I need to see the whole in it. Had I altered the main tube, it would have wholes in it at the beginning of the tut, thus the 2 similar pipes.
                            I hope this answers your question.
                            Regards
                            Mike RL
                              RegH
                              Add me to your list of admirers- a very neat and well thought-out tutorial.
                              Just a little feedback:
                              A- On my little LCD monitor (1024 x 768 display)the explanatory text is chopped off at the right end on the longer lines.
                              B- I think the title could be "Making holes through a solid cylinder". I would like to see you make the cylinder a hollow tube, and make the "cross perforations" appear to be as if a hollow pipe had holes drilled through the sides.
                              Of course, I may be missing something, maybe my settings?
                              Again- thanks for the nice work 👍
                              Edit: Checked it on my laptop (1440 x 900) and got better display, although text still seems to be biased toward right side of screen. Hope I don't seem to picky, just feedback. 😄
                              • B
                                basic.woodworks
                                The principle of a hollow tube is the exact same. I'm assuming that you would like to have a visible wall thickness?!?
                                When you draw you're pipe, you need to know the i.d. or o.d of it and wall thickness. so draw a circle of the diameter you know and use the offset tool in which ever direction and type in the thickness measurement, hit enter and simply delete the inner face (inside the pipe outline) then use the push/pull tool or create a path for the follow me tool with the line and arc tools. The rest is all the same.
                                Mike RL
                                  MT3d
                                  great tutorial.. thanx
                                  • GaieusG
                                    Hi Rich,
                                    Those tabs are for the step-by-step scenes in the tutorial. When you click on the next tab, you should be "taken" to the next scene that explains the next step.
                                    As for your display problem, try this: Go to Window (Sketchup on Mac) > Preferences > OpenGL settings and try to fiddle aound the different checkboxes.
                                    Most probably there is an issue with your video card/driver (if it's a laptop, maybe you have an integrated chipset on it which is not good news).
                                    Disabling Hardware acceleration may help you but then SU will be slower. Try to update your video driver (or get a edicatd video card).
                                    • GaieusG
                                      There should be only screen text on the first page/scene.
