    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • jgbJ
      jgb
      Pilou
      That answer is NOT good enough. I get the very same problem 4 times out of 5 to the point I have stopped using that arc tool. IT DOES NOT WORK properly.
      I have tried all sorts of variations, on a grouped surface, on a component surface, on a surface that was selected, on a surface with lines shown, lines not shown, endpoint to endpoint. Same result every time. Twisted lines in space, very few on the surface and otherwise useless.
      When it works, it works wonders. When it doesn't it takes me about a 1/2 hour to create a curve the old fashioned way with intersecting extrusions.
      I have complained about this several times in the past, nothing changed.
      Please fix it!
      jgb
        Maybe try to subdivide surface before if that works not as you want!
        • jgbJ
          jgb
          I've tried to select only faces that I know will contain the curve. That did not work either.
          jgb
            Have you an Skp file example?
            • A
              applemango85
              Sorry I'm still having no joy with the arc
              I've been using the ellipse tool instead. But even that is hit and miss. The tools don't always draw on the surface and draw weirdly on the x or y axis instead. I seem to get success when a purple dots show up but more often then not it's the red star for the intersection.
              I'd love to sing the praises of this plugin because it's a great concept but I need help to get it working properly
                Upload an example SKP file with a surface on which you can't draw a curve. Give us something to work with. Maybe we can help.
                • A
                  applemango85
                  sorry just done it now
                  Ive been using a separate group with lines as a guide.
                  Ive been using the ellipse tool instead of the arc as the arc tool will not draw a solid line.
                  the plan is once the 4th ellipse is drawn to delete the above area then delete the Bottom of the ellipse lines (first time I did this I did a few of the measurements wrong so I know it works I just need to do it again)
                  thank you all in advance
                  tools on surface.skp
                    The group you created as a guide is getting in the way of letting the tool work properly.
                    I copied the top edge of the cylinder down to give me a base line for the arcs and set a few guidelines to locate the ends of the arcs. The Arc on Surface tool works just fine.
                    Click to animate
                    • A
                      applemango85
                      think that my guides were drawn wrong so I redraw I but now I have the problem that the ellipses round is made up of many little lines not the one line which is a tad of a problem when trying to use jointpushpull on the cylinder surface
                      • A
                        applemango85
                        thank you dave - ill see if that works now
                          It's hard to tell what you have going on now without seeing the file.
                          • A
                            applemango85
                            well I'm getting a solid line but my arc isn't happening - its either a mess or something like the attachment
                            tools on surface.pdf
                            • A
                              applemango85
                              oh my goodness, I think I got it to work - I deleted a few of the guidelines and zoomed out - not the prettiest looking object but it does the job
                              thank you for sparing the time to help
                              the key seems to be to note where the blue/purple dots appear and keep guides to a minimum
                              test 1.skp
                                Good for you. If you use the inferencing tools you really shouldn't need much in the way of guides.
                                • A
                                  aofaofaof
                                  thanks
                                  • T
                                    tonamu
                                    Thanks for share.
                                    tonamu
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: Tools on Surface 2.3a- 06 Oct 17
                                      This maintenance release is required for:
                                      • the support of usernames with non-ascii characters
                                      • the compatibility for High Sierra for Mac users
                                      • the support for hi-resolution screens
                                      • the certification for SU2017
                                      You will need to migrate to LibFredo6 7.7g or higher
                                      Please see main post for download
                                      Fredo
                                      • R
                                        rv1974
                                        Fredo would it be hard to add fillet tool please?
                                        • fredo6F
                                          fredo6
                                          What do you mean?
                                          This is a set of tools "on Surface".
                                          Fredo
                                          • R
                                            rv1974
                                            I mean fillet on 3d surface. See attached:
                                            Say you have AB and CD lines. The red fillet connectig AB abd CD is demanded.
                                            fil.skp
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 28 / 32
