    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • O Offline
      otb designworks
      Fantastic!
      This script is amazing and I don't know how I survived without it.
      Thank you so much for the update; YAY!!
      Cheers, Chuck
      OTB Designworks is on Youtube
        ...I don't know how I survived without it...
        I guess it spares about 70-80% of previous, tedious intersection works now!
        • K Offline
          kwistenbiebel
          wow...Thank you Fredo for this wonderful plgin.
          Much appreciated and a great contribution to the SU community. 👍
            tomasz
            Thanks a lot Fredo! Great work!
            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
            • MALAISEM Offline
              MALAISE
              Fredo6, only one word : Great ....
              Thx from members of the community 😎
              • G Offline
                gaganraj
                for some reason after installing the new script, my entire Tools On Surface tool box disappeared?!
                • soloS Offline
                  solo
                  Thanks a ton mate, your tools are now native to my workflow, without them I would be so less productive.
                  http://www.solos-art.com
                    Matt666
                    Go to the menu "Window/Preferences/Extensions/" and check the fredo line !
                    Frenglish at its best !
                    My scripts
                    • G Offline
                      gaganraj
                      😳 thanks! doh!
                        Teezer
                        Thank you, sir! 😎
                        Real life is just another website, albeit a rather boring one.
                          sepo
                          Fantastic tools.. Thanks very much.
                          • Didier BurD Offline
                            Didier Bur
                            Salut Fredo,
                            The doc is updated in English, and in French (partially translated).
                            🤣 Ah Ah Ah C'est un comble !!! (moi c'est pire je ne traduis pas du tout)
                            Great great great plugin 👍 👍 👍
                            DB
                            • EdsonE Offline
                              Edson
                              Edson,
                              It looks like you have something rescued from version 1.1. Did you delete the older files?
                              i threw away the entire v1.2 folder. any clues as to which file i should look for?
                              http://www.mahfuz.arq.br
                              • fredo6F Offline
                                fredo6
                                Edson,
                                Check if one of these files is still in the Plugins folder.
                                • LibOnSurface.rb
                                • OffsetOnSurface.rb
                                • LineOnSurface.rb
                                • PolygonOnSurface.rb
                                • EraserOnSurface.rb
                                • PolylineOnSurface.rb.
                                I am not familiar with how scripts install on Mac, but it seems that you have an old LineonSurface.rb and Offset_on_surface.rb which is active and loaded.
                                • EdsonE Offline
                                  Edson
                                  Edson,
                                  • LibOnSurface.rb
                                  • LineOnSurface.rb
                                  the 3 first ones were lying around, outside the TOS folder. i deleted them and that did the trick. thanks.
                                  • CadFatherC Offline
                                    CadFather
                                    i must say i enjoy just looking at the way the plugin draws the shapes with those red lines...
                                    and i noticed if you draw 2 overlapping faces it even knows the intersections! (when drawn on faces)
                                    Thank You and Amazing!! ☀
                                    • urgenU Offline
                                      urgen
                                      ...thanks! 👍
                                      --pupil forever...------
                                      • W Offline
                                        watkins
                                        Dear Fredo,
                                        An amazing gift to the Sketchup community. Thank you so much for all your hard work and for your generosity.
                                        Kind regards,
                                        Bob
                                          rv1974
                                          1. Brilliant! Many thanks.
                                          2. Is there a way to set up number of segments in your curvy tools?
                                            @rv1974 said:
                                            1. Is there a way to set up number of segments in your curvy tools?
                                            Just like with the regular tools: after drawing the circle/polygon, type a number followed by a letter s and hit enter.
                                            • 31
                                            • 32
                                            • 2 / 32
