    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • MALAISEM
      MALAISE
      Fredo6, only one word : Great ....
      Thx from members of the community 😎
      • G
        gaganraj
        for some reason after installing the new script, my entire Tools On Surface tool box disappeared?!
        • soloS
          Thanks a ton mate, your tools are now native to my workflow, without them I would be so less productive.
            Matt666
            Go to the menu "Window/Preferences/Extensions/" and check the fredo line !
            Frenglish at its best !
            My scripts
            • G
              gaganraj
              😳 thanks! doh!
              • T
                Teezer
                Thank you, sir! 😎
                Real life is just another website, albeit a rather boring one.
                  sepo
                  Fantastic tools.. Thanks very much.
                  • Didier BurD
                    Didier Bur
                    Salut Fredo,
                    The doc is updated in English, and in French (partially translated).
                    🤣 Ah Ah Ah C'est un comble !!! (moi c'est pire je ne traduis pas du tout)
                    Great great great plugin 👍 👍 👍
                    DB
                    • EdsonE
                      Edson
                      Edson,
                      It looks like you have something rescued from version 1.1. Did you delete the older files?
                      i threw away the entire v1.2 folder. any clues as to which file i should look for?
                      http://www.mahfuz.arq.br
                      • fredo6F
                        Edson,
                        Check if one of these files is still in the Plugins folder.
                        • LibOnSurface.rb
                        • OffsetOnSurface.rb
                        • LineOnSurface.rb
                        • PolygonOnSurface.rb
                        • EraserOnSurface.rb
                        • PolylineOnSurface.rb.
                        I am not familiar with how scripts install on Mac, but it seems that you have an old LineonSurface.rb and Offset_on_surface.rb which is active and loaded.
                        • EdsonE
                          Edson
                          Edson,
                          • LibOnSurface.rb
                          • LineOnSurface.rb
                          the 3 first ones were lying around, outside the TOS folder. i deleted them and that did the trick. thanks.
                          • CadFatherC
                            CadFather
                            i must say i enjoy just looking at the way the plugin draws the shapes with those red lines...
                            and i noticed if you draw 2 overlapping faces it even knows the intersections! (when drawn on faces)
                            Thank You and Amazing!! ☀
                            • urgenU
                              urgen
                              ...thanks! 👍
                              --pupil forever...------
                              • W
                                watkins
                                Dear Fredo,
                                An amazing gift to the Sketchup community. Thank you so much for all your hard work and for your generosity.
                                Kind regards,
                                Bob
                                  rv1974
                                  1. Brilliant! Many thanks.
                                  2. Is there a way to set up number of segments in your curvy tools?
                                  • GaieusG
                                    @rv1974 said:
                                    1. Is there a way to set up number of segments in your curvy tools?
                                    Just like with the regular tools: after drawing the circle/polygon, type a number followed by a letter s and hit enter.
                                      dylan
                                      Thanks Fredo, this looks amazing and will be a real help with my modelling 👍
                                      http://dmdarchitecture.co.uk/
                                        matteo
                                        Fredo, your work is incredible.
                                        Thank you for this new release
                                        hire me: http://www.nonsolo3d.it/ !
                                        • CadFatherC
                                          CadFather
                                          i am getting strange results with circle or rectangle on a sandboxed surface
                                          oops and i can't seem to attach images anymore! (file is not valid) 😞
                                            arcano
                                            awesome!!!
                                            • 31
                                            • 32
                                            • 2 / 32
