    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      Banjo
      Hey! I'm new member at Sketchucation. Wonder how I can get the plugin "Tools on surface"
      regards /Banjo
      @hassanykb said:
      :ecstatic: this is a life saver man!!!
      you rock Fredo!
        Hi Banjo,
        Download it from the first post of this topic.
        • P Offline
          potatochips
          why does it say there's an error???
          http://i56.tinypic.com/23j4ltd.gif
          Error Loading File ZLoader__OnSurface.rb
          no such file to load -- LibFredo6.rb
            Hi Potatochips,
            Have you also installed the LibFredo library as advised in the first post?
            • P Offline
              potatochips
              @gaieus said:
              Hi Potatochips,
              i got it to work now, thanks!
                Ruturaj
                Hello sir,
                your new version is working on google-sketchup pro 8 ...... ?
                Thank you,
                Ruturaj
                Thanks,
                RuturaJ
                  yes - it work with SU8
                    Ruturaj
                    Thank you ,..... 😄
                    Thanks,
                    RuturaJ
                      You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
                        davidheim1
                        Does Tools on Surface run on SU 8? I've tried to download and install it just as you described, but I can't seem to get it to appear in either the Tools menu or the Plug Ins menu, even after I restart my computer. I have the Dir 35 running on my computer. Any suggestions?
                        As always, many thanks
                          It works on SU8, yes.
                          Exactly what location did you install it to? can you post a print screen of where you files are?
                            davidheim1
                            It's in the Macintosh HD/Library/Application Support/SU8/Plug-Ins. Here's a screen shot:
                            • jeff hammondJ Offline
                              jeff hammond
                              i'm not quite sure how you ended up with a folder called 'ToolsOnSurface 1.6c - 15 May 10(3)' but it's not correct..
                              the simplest way for you to install would be to download the installer here:
                              http://web.me.com/jeffhammond/su/TOS.zip
                              (this was made for someone else a little while ago.. su8 osx only)
                              you'll probably want to trash the ToolsOnSurface 1.6c - 15 May 10(3) folder
                              dotdotdot
                                It's it the content of 'ToolsOnSurface 1.6c - 15 May 10(3)' that should be in the plugins folder?
                                  jeff hammond
                                  that's what i was thinking as well.
                                  though when i unzip the download, i'm left with a folder called ToolsOnSurface%201 which then needs to be opened to find the goodies.
                                  dotdotdot
                                    davidheim1
                                    I trashed the ToolsOnSurface folder and used your installer to reinstall the program. Still no luck. Can't find the plug-in even when I restart SU 8. Does it matter that I'm using SU Pro?
                                    Many thanks for your help.
                                    dh
                                      jeff hammond
                                      you might have to enable the plugin
                                      go sketchup-> preferences-> extensions
                                      and check tools on surface
                                      pro doesn't matter
                                      dotdotdot
                                        davidheim1
                                        pro doesn't matter
                                        Tools on Surface is enabled. But the plug-in still doesn't appear. I really don't know what to do. These fredo6 plug-ins always give me fits.
                                        • mitcorbM Offline
                                          mitcorb
                                          Do you have the current LibFredo file in place, or does that matter here?
                                            davidheim1
                                            Yes. Current LibFredo file is in place. I even downloaded LibFredo Dir_34, even though I have Dir_35 installed. Arrgh!
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
