    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • Z
      zilvinasz
      😍 DUDEEE!!!! your just bringin Sketchup alive!!!
      Thanks!!!
        rachmatrf
        YOU'RE THE MAN FREDO!!
          Daniel S
          There is a small problem with the polygon of 3 segments on the red axis working on 2D.
          It creates the triangle but in the other direction. On a surface works right.
          Daniel S
            derweissi
            After installing this great Plugin - I unzipped it in the plugin folder - I only get following message when starting sketchup and can't use it now. Whats wrong ? Did i make a mistake?
            Fehler beim Laden der Datei __loader.rb
            uninitialized constant TraductorFehler beim Laden der Datei EraserOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreehandOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei FreeScale_Common.rb
            uninitialized constant FreeScale::T6Fehler beim Laden der Datei FreeScale_Tool.rb
            uninitialized constant FreeScale::SU_MAJOR_VERSIONFehler beim Laden der Datei LibOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LineOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei LoaderOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetAlgoOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei OffsetOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PaletteOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei PolylineOnSurface.rb
            uninitialized constant SUToolsOnSurface::T6Fehler beim Laden der Datei ShapeOnSurface.rb
            • W
              walpurgisnacht
              I cant get fredo6 colllection to show up in my tools menu. the plugin is installed and i have it enabled in preferences but dosnt appear otherwise
                melissa11
                hi,
                doesnt seem to appear under the toolbars menu. It is turned on under preferences> extensions but I dont no where it is πŸ˜•
                new to this!
                thanks
                  melissa11
                  Hi, Did you find out the answer to your question - I have the same problem and havent figured it out yet. πŸ˜•
                    the first post doesnt make any references to libfredo...
                    • H
                      hassanykb
                      😍 this is a life saver man!!!
                      you rock Fredo!
                      • B
                        Banjo
                        Hey! I'm new member at Sketchucation. Wonder how I can get the plugin "Tools on surface"
                        regards /Banjo
                        @hassanykb said:
                        :ecstatic: this is a life saver man!!!
                        you rock Fredo!
                        • GaieusG
                          Hi Banjo,
                          Download it from the first post of this topic.
                          • P
                            potatochips
                            why does it say there's an error???
                            http://i56.tinypic.com/23j4ltd.gif
                            Error Loading File ZLoader__OnSurface.rb
                            no such file to load -- LibFredo6.rb
                            • GaieusG
                              Hi Potatochips,
                              Have you also installed the LibFredo library as advised in the first post?
                              • P
                                potatochips
                                @gaieus said:
                                Hi Potatochips,
                                i got it to work now, thanks!
                                  Ruturaj
                                  Hello sir,
                                  your new version is working on google-sketchup pro 8 ...... ?
                                  Thank you,
                                  Ruturaj
                                  Thanks,
                                  RuturaJ
                                    yes - it work with SU8
                                      Ruturaj
                                      Thank you ,..... πŸ˜„
                                      Thanks,
                                      RuturaJ
                                        You can assume that most plugins work in SU8 if they worked in earlier versions. Just install and try.
                                          davidheim1
                                          Does Tools on Surface run on SU 8? I've tried to download and install it just as you described, but I can't seem to get it to appear in either the Tools menu or the Plug Ins menu, even after I restart my computer. I have the Dir 35 running on my computer. Any suggestions?
                                          As always, many thanks
                                            It works on SU8, yes.
                                            Exactly what location did you install it to? can you post a print screen of where you files are?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
