    Slicer-excellent ruby
    19 Posts 9 Posters 11.9k Views 9 Watching
    • T
      tomislavm
      today I have found this excellent ruby and this site, http://www.rcgroups.com/forums/showthread.php?t=826409
      Slicer3.zip
      • H
        HFM
        Great! I've been waiting for this one ever since 'Slicer2' !!!
        No seriously what does it do,... info ? πŸ˜„
        • plot-parisP
          plot-paris
          what is it doing? sounds a bit like Zorro... πŸ˜‰
          • T
            tomislavm
            sketchup model slice in parts by x or z or y.
            • T
              tomislavm
              another one
              • H
                HFM
                That's pretty fance πŸ‘
                good for creating abstract models πŸ˜„
                  Copyright 2005-2007, TIG
                  πŸ˜‰
                  Zorro is Whaat πŸ˜‰
                  And not exactly the same πŸ˜’
                  • Didier BurD
                    Didier Bur
                    This one is one my site since October 2007...
                    DB
                    • plot-parisP
                      plot-paris
                      oh my god, this is really great! and thanks for the demonstration
                      just imagine how easy it is to create a terrain model now. simply print out the sliced outlines and cut them out of a foamboard...
                      thanks a lot. I will definitely find it very useful!
                      • X
                        xrok1
                        bump! πŸ˜‰
                        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • T
                          trock2957
                          I can't believe what is capable with a free 3D program like sketchup and the amazing scripts people are giving away!
                          Several years ago I bought Rhino just to do some slice modeling. Wow!
                          Thanks so much for this great plugin.
                          • L
                            lapx
                            Why is slicer not finishing some of the slices? The shape was made with bezier curve and fredo's cuviloft function then slicer.
                            • TIGT
                              I can't be sure without having the SKP itself.
                              Can you please purge and then post the SKP in question, so I can run some tests on it pre/post Slicing...
                              If it's 'confidential' then attach it to a PM to me... πŸ˜‰
                              • L
                                lapx
                                Thanks Tig! Here ya go.
                                fredo.skp
                                • TIGT
                                  My initial look through this finds no issues with the SKP OR with Slicer itself... BUT it DOES miss out vital edges in some random slices whatever settings I try too - which [at the moment is inexplicable, and] I am looking at πŸ˜• πŸ˜• πŸ˜•
                                  I'll continue looking and report back... any one else who wants to chip in please do... I am currently at a loss............
                                  • TIGT
                                    The problem seems to be that the built-in AND API's 'intersect' method fail to intersect a seemingly coplanar face with a cutting plane.
                                    Try this by hand to see that you cannot cut an intersected loop through some faces... the error occurs at a few non-triangulated faces as I show in the image... IF you triangulate the problem facet then the problem doesn't occur πŸ˜’
                                    Similarly IF you use my triangulate tool on ALL of the faces [selected inside the object], THEN when using Slice it works fine... therefore it seems a weirdness in the 'intersect' method not taking a quad face as cutting as it is perhaps not quite coplanar in its 4 edges... BUT it is thought coplanar enough to be considered one face when it's NOT triangulated and so it exists and display OK ??????fredo.PNG
                                    • L
                                      lapx
                                      Tig your are a genuis! I'm not familiar with your triagulation tool but I'll look into it.
                                      I hope its as simple as selecting all faces and executing the command πŸ˜‰
                                      Thanks for the help Tig!
                                      • L
                                        lapx
                                        Tig again, I must thank you! It worked like a charm.
                                        • TIGT
                                          I have reported the weirdness to the powers that be at Google - it is certainly reproducible although I had never seen it before... Meanwhile the temp fix 'Triangulate Faces' is here http://forums.sketchucation.com/viewtopic.php?p=175613#p175613 for the rest of you...
