    Slicer-excellent ruby
    19 Posts 9 Posters 11.9k Views 9 Watching
    • T
      tomislavm
      another one
      • H
        HFM
        That's pretty fance πŸ‘
        good for creating abstract models πŸ˜„
          Copyright 2005-2007, TIG
          πŸ˜‰
          Zorro is Whaat πŸ˜‰
          And not exactly the same πŸ˜’
          • Didier BurD
            Didier Bur
            This one is one my site since October 2007...
            DB
            • plot-parisP
              plot-paris
              oh my god, this is really great! and thanks for the demonstration
              just imagine how easy it is to create a terrain model now. simply print out the sliced outlines and cut them out of a foamboard...
              thanks a lot. I will definitely find it very useful!
              • X
                xrok1
                bump! πŸ˜‰
                • T
                  trock2957
                  I can't believe what is capable with a free 3D program like sketchup and the amazing scripts people are giving away!
                  Several years ago I bought Rhino just to do some slice modeling. Wow!
                  Thanks so much for this great plugin.
                  • L
                    lapx
                    Why is slicer not finishing some of the slices? The shape was made with bezier curve and fredo's cuviloft function then slicer.
                      I can't be sure without having the SKP itself.
                      Can you please purge and then post the SKP in question, so I can run some tests on it pre/post Slicing...
                      If it's 'confidential' then attach it to a PM to me... πŸ˜‰
                      • L
                        lapx
                        Thanks Tig! Here ya go.
                        fredo.skp
                          My initial look through this finds no issues with the SKP OR with Slicer itself... BUT it DOES miss out vital edges in some random slices whatever settings I try too - which [at the moment is inexplicable, and] I am looking at πŸ˜• πŸ˜• πŸ˜•
                          I'll continue looking and report back... any one else who wants to chip in please do... I am currently at a loss............
                            The problem seems to be that the built-in AND API's 'intersect' method fail to intersect a seemingly coplanar face with a cutting plane.
                            Try this by hand to see that you cannot cut an intersected loop through some faces... the error occurs at a few non-triangulated faces as I show in the image... IF you triangulate the problem facet then the problem doesn't occur πŸ˜’
                            Similarly IF you use my triangulate tool on ALL of the faces [selected inside the object], THEN when using Slice it works fine... therefore it seems a weirdness in the 'intersect' method not taking a quad face as cutting as it is perhaps not quite coplanar in its 4 edges... BUT it is thought coplanar enough to be considered one face when it's NOT triangulated and so it exists and display OK ??????fredo.PNG
                            • L
                              lapx
                              Tig your are a genuis! I'm not familiar with your triagulation tool but I'll look into it.
                              I hope its as simple as selecting all faces and executing the command πŸ˜‰
                              Thanks for the help Tig!
                              • L
                                lapx
                                Tig again, I must thank you! It worked like a charm.
                                  I have reported the weirdness to the powers that be at Google - it is certainly reproducible although I had never seen it before... Meanwhile the temp fix 'Triangulate Faces' is here http://forums.sketchucation.com/viewtopic.php?p=175613#p175613 for the rest of you...
