    S&S sculptures
    18 Posts 7 Posters 1.7k Views 7 Watching
    • plot-parisP Offline
      plot-paris
      hi everybody,
      after seeing how kwistenbiebel lives on that other planet, I simply had to buy the wonderful Subdivide & Smooth tool.
      this is my first go with it. its just a quick try (the rendering took quite long though - a lot of transparency, reflection and 16 multisurfaced light sources ๐Ÿ˜‰ )
      http://img379.imageshack.us/img379/7075/exhibitionstandem4.jpg
      @Fred: you should really start rendering (indigo is very easy to use) - your sculptures would look marvellous...
      • I Offline
        igor
        what renderer are you using? indigo?
        you model looks to me to be a very stylish book case with lots of light emitting books on it.
        i like it.
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
        • P Offline
          princedragoncok
          nice! could be developed into some cool furniture
          • K Offline
            kwistenbiebel
            Very nice Plot-Paris ๐Ÿ˜„
            And I see you are using Indigo Render. And a fine render it is.
            I didn't know one could use an image as emitter. Learning every day.๐Ÿ˜„
            Did you just make a textured SU material into an emitter by double clicking and assigning blackbody?
              remus
              Nice renders jakob, i like the iphone ones as well.
              If you want to get big pics on here you'll nee to upload thme to somewhere else and then link them here using the [img] tag. Give us a shout if oyu have any trouble with this, it can be a bit tricky to work out the first time you do it.
                plot-paris
                thanks, remus. now it is working (see above) - indeed easy, when you know how to do it ๐Ÿ˜„
                  remus
                  it should look sometihng like this: [img]imgurl[/img]
                  You can get the image URL by right clicking the image->properties.
                    Julius
                    i still can't see the images ๐Ÿ˜ž
                    • I Offline
                      igor
                      nither can i. i want to see them!
                        johnsenior1973
                        If you want to see his pictures and they are just coming up as red crosses you can just right click on the crosses, click on Properties, then highlight the web address, copy it, then paste the address straight into your web browser.
                        • I Offline
                          igor
                          to me it just says "image" exept with out the quotes. i was able to see the pic before, did you edit anything in the first post plot-paris?
                            plot-paris
                            sorry, I am at a complete loss - why is this happening? did I do something wrong?
                            when I copy the link in the properties (right klick) and paste it as new url, the images are integrated into the post, but not before that...
                            what do I have to change? I am desperate for help ๐Ÿ˜ž
                              Julius
                              you could also remove the img tags so there's the link alone.
                              or you could upload the image with ImageShack.
                                plot-paris
                                I uploaded the images to a picasa web album. shouldn't that work the same way? the pictures are definitely online (you can see them by following the link after all)
                                how do you other guys do that?
                                [Edit] I changed it into links now. but if you klick on them, they dont work - you have to select the url again and press enter to see it. strange ๐Ÿ˜ž
                                  plot-paris
                                  thanks for the kind replies.
                                  kwistenbiebel, this isn't an image light. the cubes are 3D objects with red plastic on extruded faces (I violated the zorro ruby to create them ๐Ÿ˜‰ ) and an ordinary blackbody light on the remaining faces.
                                  but indigo does indeed allow textured lights (look at the example of my personal big iPhone ๐Ÿ˜‰ ๐Ÿ˜ž
                                  http://img379.imageshack.us/img379/9668/icinemacz3.jpg
                                  ps: how do you get pictures showing up full size here in the forum (mine are allways rather small...)
                                    plot-paris
                                    thanks, remus. ok, lets try linking a picture to picasa...
                                    http://img379.imageshack.us/img379/9995/tripodhotelmv2.jpg
                                    [Edit] obviously this didn't work. how am I supposed to embedd the link into the img tags?
                                    [Edit]thanks, remus. now it is working - indeed easy, when you know how to do it ๐Ÿ˜„
                                    by the way: this is not really a perfect example for the use of S&S (it was only used to smooth it a bit, but didn't influence the shape itself).
                                    I want to live at the top floor (and ask kwistenbiebel to do the interior design ๐Ÿ˜† ).
                                    I did not dare do design the developement of the building though - a lift will be quite tricky to install ๐Ÿ˜•
                                      plot-paris
                                      thanks a lot Julius.
                                      I had a look at imageshack, (when my boss wasn't watching for a minute) - and it is working! at least I hope it is. can you see the images now? ๐Ÿ˜•
                                        Julius
                                        yes! and i like them! especially i like the look of the glass in the first render.
