    S&S sculptures
    18 Posts 7 Posters 1.8k Views 7 Watching
      Julius
      i still can't see the images 😞
      • I Offline
        igor
        nither can i. i want to see them!
        The genius switch has no "off" position
        Intelegence is natrual, it takes real effort to be ignorant
          johnsenior1973
          If you want to see his pictures and they are just coming up as red crosses you can just right click on the crosses, click on Properties, then highlight the web address, copy it, then paste the address straight into your web browser.
          • I Offline
            igor
            to me it just says "image" exept with out the quotes. i was able to see the pic before, did you edit anything in the first post plot-paris?
            • plot-parisP Offline
              plot-paris
              sorry, I am at a complete loss - why is this happening? did I do something wrong?
              when I copy the link in the properties (right klick) and paste it as new url, the images are integrated into the post, but not before that...
              what do I have to change? I am desperate for help 😞
                Julius
                you could also remove the img tags so there's the link alone.
                or you could upload the image with ImageShack.
                  plot-paris
                  I uploaded the images to a picasa web album. shouldn't that work the same way? the pictures are definitely online (you can see them by following the link after all)
                  how do you other guys do that?
                  [Edit] I changed it into links now. but if you klick on them, they dont work - you have to select the url again and press enter to see it. strange 😞
                    plot-paris
                    thanks for the kind replies.
                    kwistenbiebel, this isn't an image light. the cubes are 3D objects with red plastic on extruded faces (I violated the zorro ruby to create them πŸ˜‰ ) and an ordinary blackbody light on the remaining faces.
                    but indigo does indeed allow textured lights (look at the example of my personal big iPhone πŸ˜‰ 😞
                    http://img379.imageshack.us/img379/9668/icinemacz3.jpg
                    ps: how do you get pictures showing up full size here in the forum (mine are allways rather small...)
                      plot-paris
                      thanks, remus. ok, lets try linking a picture to picasa...
                      http://img379.imageshack.us/img379/9995/tripodhotelmv2.jpg
                      [Edit] obviously this didn't work. how am I supposed to embedd the link into the img tags?
                      [Edit]thanks, remus. now it is working - indeed easy, when you know how to do it πŸ˜„
                      by the way: this is not really a perfect example for the use of S&S (it was only used to smooth it a bit, but didn't influence the shape itself).
                      I want to live at the top floor (and ask kwistenbiebel to do the interior design πŸ˜† ).
                      I did not dare do design the developement of the building though - a lift will be quite tricky to install πŸ˜•
                        plot-paris
                        thanks a lot Julius.
                        I had a look at imageshack, (when my boss wasn't watching for a minute) - and it is working! at least I hope it is. can you see the images now? πŸ˜•
                          Julius
                          yes! and i like them! especially i like the look of the glass in the first render.
